Changing To Led Bulbs
8 replies to this topic
#1 matt050990
matt050990
    I have upside down nipples
  • 1,199 posts
  • Local Club: Currently Ridin' Solo :)
Posted 28 June 2020 - 07:23 AM
hi all
Short and sweet question.....
If I was to swap all my bulbs in the rear lights to led to increase brightness, is it just a straight swap? Or is there more to it?
Much ta
Matt
#2 tommy boy
tommy boy
  • 197 posts
Posted 28 June 2020 - 08:05 AM
Stop /tail and reverse (if you have them) would work fine. Could be a different story with the indicators though. Because the flasher can uses resistance (both normal and 4 ways) the new led lamps will have a lower resistance value and not work. Some do, some not. If it don`t work properly, adjustable flasher cans can be found on ebay. I had to fit both on mine.
#3 Mini Manannán
Mini Manannán
  • 2,860 posts
  • Local Club: man Estate
Posted 28 June 2020 - 08:25 AM
As about, you'll need the flasher that can cope with the resistance.
A word of warning, don't buy the first LEDs you find, they are not the same. I use this company, their LEDs are good quality: https://www.classicc...lays-electronic
#4 matt050990
matt050990
  • 1,199 posts
Posted 28 June 2020 - 01:35 PM
Thanks for the above, main ones I was looking to change was the brake lights so will look at that link.
Ta
#5 Steve220
Steve220
  • 5,146 posts
  • Local Club: BMC
Posted 28 June 2020 - 01:57 PM
Changed all my van's bulbs to ebay LED ones, hazards and indicators work fine. Car lights up like an xmas tree now :lol:
#6 Mini Manannán
Mini Manannán
  • 2,860 posts
Posted 28 June 2020 - 08:48 PM
Remember you'll need to use red LEDs in trail/stop lights, half way down the page here: https://www.classiccarleds.co.uk/
#7 matt050990
matt050990
  • 1,199 posts
Posted 29 June 2020 - 07:15 AM
Did you have to change the flasher unit to work with the LEDs or did you get away with straight swap?
#8 bikewiz
bikewiz
  • 321 posts
  • Local Club: NEMO
Posted 29 June 2020 - 11:53 AM
You'll need to change to an electronic flasher unit or run resistors at the LEDs.
This type. https://www.superbri...lasher/782/836/
or resistors. https://www.superbri...arning-fix/190/
Look at the Youtube videos from Headlight Revolution they answer all questions LED. https://headlightrevolution.com/
#9 matt050990
matt050990
  • 1,199 posts
Posted 29 June 2020 - 12:14 PM
Spot on, thanks mate
