Loud Ticking Noise From Engine
13 replies to this topic
#1 positha7
positha7
    Starting My Mini Up
  • 3 posts
Posted 28 June 2020 - 03:11 PM
hi guys my 1999 rover mini SPI has been sitting in the garage for one month, started it up and there's a loud ticking type noise coming from the engine, two days back i did following things through local mini shop
full engine oil change (20W-50)
air filter and oil filter change
tappet adjustment
engine tuneup
Millage - 93,000km
anyone got any ides what it could be?
cheers
#2 sca
sca
  • 26 posts
Posted 28 June 2020 - 05:28 PM
have you adjusted tappets corectly
#3 sonikk4
sonikk4
    Twisted Paint Polisher!!!
  • 16,188 posts
  • Name: Neil
Posted 28 June 2020 - 06:35 PM
It does sound like the garage has not adjusted the tappets correctly.
#4 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 28 June 2020 - 08:38 PM
Incorrect tappet adjustment
#5 MiniMadRacer
MiniMadRacer
  • 906 posts
Posted 28 June 2020 - 08:57 PM
As above i would suspect the tappets.. you could run the engine with the rocker cover removed, and put a screw driver end to one of the rocker posts and listen to the other end with your ear (very carefully of course) which might help amplify the sound and confirm the rockers... given the mileage though it could be rocker shaft wear not just adjustement..
#6 PACINO
PACINO
  • 821 posts
Posted 29 June 2020 - 03:26 AM
https://youtu.be/ZFvwyCroV2w
#7 positha7
positha7
    Starting My Mini Up
  • 3 posts
Posted 30 June 2020 - 07:00 AM
Thank you very much for your responses, i am currently checking each one of them. very much appreciate if you could tell me any other  ways to check.
#8 positha7
positha7
    Starting My Mini Up
  • 3 posts
Posted 05 July 2020 - 04:29 PM
Hi All,
I have tried the ways you have suggested, i think the issue is in rocker's, let me know how to resolve this issue?
#9 Cooperman
  • 23,566 posts
Posted 05 July 2020 - 04:45 PM
Adjust the valve clearances to 0.015" with the engine cold.
Put the car in 2nd gear with the handbrake off and push the car until one valve is fully open. Deduct the number of that valve from 9 and the result is the valve number which you adjust.
For example, with valve no. 2 fully open adjust valve no. 7.
Keep moving the car and note which valves have been adjusted untill you have done all 8. You need a screwdriver, a 1/2" AF spanner and a set of imperial feeler gauges.
#10 beardylondon
beardylondon
  • 1,791 posts
Posted 05 July 2020 - 05:05 PM
I asked this question recently and I was told 12 thou?
#11 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 05 July 2020 - 05:19 PM
You can use 12 thou but only if the tappets are worn
#12 beardylondon
beardylondon
  • 1,791 posts
Posted 05 July 2020 - 05:35 PM
positha has done 93k, so probably worn!
I thought 15 thou made it more noisy?
#13 imack
imack
  • 2,381 posts
Posted 05 July 2020 - 06:18 PM
I've always used 12 thou for standard cams and rockers.
#14 Spider
  • 15,848 posts
Posted 05 July 2020 - 06:43 PM
For most stock engines, 12 thou is what the factory recommend, however for some, like the (original) Cooper S they did recommend 15 thou for 'hard' use and off hand, the MG Metro had different settings for Inlet and Exhaust.
If after setting them you find the noise is still there and is def comming from the rockers, it might well be a worn rocker shaft, which after 93k miles, I would say is par for the course.
