23D Or 43D Dizzy
3 replies to this topic
#1 Minigman
Minigman
  • 803 posts
Posted 28 June 2020 - 05:17 PM
What dizzy would a ‘74 1275GT have?
I’m not running a vac advance.
Going to buy a Swiftune CSI so welcome opinions.
What is the actual difference between the 23/5D and 43/45D distributors and can either be used on a pre A+ engine with the older 2 bolt type clamp?
Edited by Minigman, 28 June 2020 - 06:05 PM.
#2 croc7
croc7
  • 894 posts
Posted 19 July 2020 - 07:51 PM
I have a Swiftune CSI and am very satisfied with it.  It has a variety of different curves from road to race applications
that are easy to change.  Pretty sure that the 43/45 can't be used on pre A+ engines.  Something to do with the length of the distributor shaft and the clamp.
#3 Spider
  • 15,859 posts
Posted 19 July 2020 - 08:59 PM
The 45D4 as best I can determine was introduced to the range about Jan / Feb 1974.
Curves aside, there's really no difference between them, however, if you are considering running a higher voltage HT system, the 45D4 being a bigger diameter wil cope better.
Noted you are considering a CSI and really, when going to these, it's just a matter of your own personal preference and what might be period correct as far as appearance goes.
#4 Minigman
Minigman
  • 803 posts
Posted 19 July 2020 - 10:47 PM
Mine is a late ‘74. Speaking with Swiftune I went for the 23D as basically there’s no difference to speak of, although the 43/45D was used until about 1980 when the A+ came into play.
I’m unlikely to ever own a later mini than my ‘74 Mk3 so the 23D made sense. In fact I’m more likely to buy more mk1s if any more minis are bought.
Edited by Minigman, 19 July 2020 - 10:49 PM.
