Alloy Inlet Manifold Studs
5 replies to this topic
#1 jamie1604
jamie1604
  • 24 posts
Posted 29 June 2020 - 08:34 PM
Evening all, I have recently fitted a stage one kit to my mini including an alloy inlet manifold and cone air filter. I am having clearence issues between the carb and bulkhead, it doesnt seem to fit!!! I have HS4 carb with standard 13.5 mm alloy spacer. Anyone point out what i need to do/what im doing wrong please!!!!
The kit was from mini sport, but the studs i was sent seem to long and the other studs i ordered have a different thread size to the inlet manifold.
Please help!!!!!!
#2 blacktulip
blacktulip
  • 6,231 posts
Posted 29 June 2020 - 08:47 PM
Post up a picture and we can take a look. Sometimes aftermarket inlets are too long. But usually the hs4 carb works with most.
#3 cal844
cal844
  • 9,733 posts
  • Local Club: TFMOC
Posted 29 June 2020 - 09:43 PM
I have the Minispares cast type inlet manifold and I can fit the carb no problems with the small plastic spacer and the studs in the kit. I buy specifically from Minispares, I see a friend of mine who is restoring a car to order it and I give him the money once the parts arrive. It's a good way to save money and hassle too
#4 mini-mad-mark
mini-mad-mark
  • 925 posts
  • Local Club: northants wot no brakes
Posted 29 June 2020 - 10:51 PM
Please help!!!!!!
When you say the "other studs" you ordered are a different thread to the manifold you may have ordered the studs which go from head to manifold which are 5/16 UNF both ends (they maybe listed as manifold studs I guess) , whereas the actual manifold stud (i.e. the stud that fixes the carb to the manifold itself) are 5/16 UNF on the "outside" (i.e. where the nut goes) and 5/16 UNC into the manifold
Sorry no help with the carb clearance fitting itself. Per Cals post I used a mini spares manifold with no issue
#5 mini-mad-mark
mini-mad-mark
  • 925 posts
Posted 29 June 2020 - 11:18 PM
So these are called "inlet/ehaust manifold studs" by MiniSport: (note 5/16 UNF both ends)
Attached File  Capture2.JPG   17.64K   2 downloads
Whereas the manifold stud is actually this one (UNF and UNC)
Attached File  Capture3.JPG   14.67K   1 downloads
But there is also this "long" one so maybe you got these in error
Attached File  Capture5.JPG   13.62K   4 downloads
#6 blacktulip
blacktulip
  • 6,231 posts
Posted 30 June 2020 - 01:08 PM
You need the manifold to carb studs as it Looks like you might have ordered the manifolds to head studs. Have a browse on minispares website. You really can't go wrong with using minispares for everything.
