Heater Matrix Question
Best Answer cal844 , 30 June 2020 - 09:08 AM
You need a new matrix as the casing will be holding the water until you lower it from the dash rail Go to the full post
1 reply to this topic
#1 zero_wlv
zero_wlv
  • 126 posts
Posted 30 June 2020 - 08:50 AM
Just a quick question:
Is there any explanation why my heater might be leaking coolant when I undo the screws to drop it down to floor level?   Obviously doing this also tilts it forward at an angle.     Quite a substantial amount drips into the footwells.   The leak is NOT at the hose clamps.
I'd have thought the obvious answer is that there's a matrix leak that needs fixing,  but the strange thing is,   when the heater is screwed back into position and the car engine is turned on  -  water pump turning and coolant flowing  -  there is no leak!
I probably really need to dismantle it to find out but my hands are full at the moment with various other repairs.
Thanks in advance.
#2 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 30 June 2020 - 09:08 AM   Best Answer
