Cheers, Paul
Edited by Tds76, 01 July 2020 - 11:44 AM.
Best Answer Tupers , 01 July 2020 - 05:36 PM
They’re not compatible the 2 spoke mini wheel has a 70MM centre and the 3 spoke clubman wheel has a 54mm centre.
Go to the full post
Posted 01 July 2020 - 11:43 AM
Posted 01 July 2020 - 04:58 PM
From memory I think the "Mini" centre's too big, but someone with more knowledge will be able to confirm this.
Posted 01 July 2020 - 05:36 PM Best Answer
Posted 01 July 2020 - 09:57 PM
Thanks.
Looks like a change of plan is required!
Posted 02 July 2020 - 09:41 AM
There was a "MINI" one that did fit the clubby wheel that was similar to this. You'd have to try and find a used one, or you can get a NOS blank one
https://minikingdomo...steering-wheel/
Also Clubman:
s-l1600-65.jpg 64.89K
1 downloads
Edited by timmy850, 02 July 2020 - 09:49 AM.
Posted 02 July 2020 - 11:21 PM
Looks like a good option.
Cheers, Paul.
Posted 11 October 2020 - 09:51 PM
I finally got my hands on the steering wheel I wanted. Came with the correct 'MINI' centre as well which was a bonus.
Unfortunately there were a few of the typical issues - the spokes were cracked, the leather and stitching was torn, the aluminium strips were dented and when I removed the centre it left behind the clip and the paint.
First off I repaired the centre - i had to repaint some of the letters first using Humbrol paints.
Masked
IMG_2130.JPEG 17.98K
0 downloads
Finished
IMG_2134.JPEG 20.86K
0 downloads
Then the cracks
IMG_2139.JPEG 52.83K
0 downloads
Cut grooves with a small Dremel cutting wheel to the bottom of the cracks then filled with Araldite - used masking tape as 'form work'. I put on way to much Araldite so had more work to do on the next stage.
IMG_0292.JPG 71.81K
0 downloads
Filed then wet & dry
IMG_2154.JPEG 84.37K
0 downloads
Painted. I used a Duplicolor plastic primer first but it did not bite, just ran straight off. So had to wait for that to harden before wet & dry again then used normal Duplicolor grey primer - a much better result.
IMG_2196.JPEG 86.72K
1 downloads
Fitted (without the leather for now)
IMG_2198.JPEG 69.61K
1 downloads
Cheers, Paul.
