Engine Stabiliser
9 replies to this topic
#1 MikeJE
MikeJE
  • 119 posts
  • Local Club: LSMO
Posted 04 July 2020 - 06:28 PM
Dear Forum - your advice is sought again, please. Having suffered a broken manifold where it meets the exhaust I found the top stabiliser to be, well, not very stable. I understand that there is also supposed to be a stabiliser on the bottom of the engine - it's an automatic mini 30 - but I cannot find one anywhere! Can anyone advise as to whether there should be a stabiliser there and, if so, where is goes, please?
Very grateful in advance
Best wishes, and stay safe....
Mike
#2 nicklouse
  • 17,944 posts
Posted 04 July 2020 - 07:31 PM
Don’t think the Auto had a lower stabiliser.
#3 RustyAutoCityE
RustyAutoCityE
  • 320 posts
Posted 04 July 2020 - 08:13 PM
I would check my '88 Auto for you, but I cant get to the front of it at the minute!
#4 madaboutcherry
madaboutcherry
  • 539 posts
  • Local Club: no
Posted 05 July 2020 - 11:09 AM
the auto never had lower stabilisers.
#5 MikeJE
MikeJE
  • 119 posts
  • Local Club: LSMO
Posted 05 July 2020 - 12:56 PM
Ok, many thanks for that folks. I am surprised given the jolting on the auto, but I will keep a closer eye on the top stabiliser in future. Just fitted the purple bushes which will, hopefully, do the trick.
All best wishes and please stay safe
Mike
#6 nicklouse
  • 17,944 posts
Posted 05 July 2020 - 01:14 PM
Mike
Best to have rubber ones on the engine side. The polyurethane ones do not heat and will not last long.
#7 MikeJE
MikeJE
  • 119 posts
  • Local Club: LSMO
Posted 05 July 2020 - 04:38 PM
Mike
Oh! That's interesting because the ones I took off had rubber on the engine end of the bar and poly ones on the bulkhead end. I thought that was a mistake! I will keep a close watch on them and have a pair of rubber ones ready at the first sign of movement. Many thanks for that.
Best wishes
Mike
Edited by MikeJE, 05 July 2020 - 04:38 PM.
#8 Clip
Clip
  • 181 posts
Posted 05 July 2020 - 11:16 PM
I’ve had these fitted to my mini before, but not sure if they will fit your auto?
Attached File  79B9E313-886E-4B06-9F34-DC9E325900AF.jpeg   120.76K   3 downloads
Attached File  AEC54D70-D65E-4F66-BCCB-607A1FF6B83B.jpeg   143.15K   2 downloads
#9 nicklouse
  • 17,944 posts
Posted 05 July 2020 - 11:19 PM
they will not as the auto box is totally different.
#10 MikeJE
MikeJE
  • 119 posts
  • Local Club: LSMO
Posted 06 July 2020 - 09:39 AM
Many thanks, Clip, they would be a good option, although Nicklouse says the auto box is different. I will have a good look underneath, though, to see if I can rig up something similar just to give a bit more stability. I did try minispares additional stabiliser   https://www.minispar...c/MSSK1000.aspx but there was no way I could get it to fit as all the hoses were in the way.
As always, many thanks for the wisdom of the forum
Best wishes
Mike
