Seat Belts
Posted 04 July 2020 - 08:41 PM
Posted 04 July 2020 - 09:42 PM
CHM113 if we're thinking of the same bit. You may get lucky on Ebay it was used on other models.
Posted 04 July 2020 - 10:13 PM
CHM113 superseded by EMZ100250PMA, which in turn was superseded by EWP100130PMA, & they appear to be available from Somerfield-
http://www.somerford...roducts_id=7763
Posted 04 July 2020 - 10:55 PM
Posted 05 July 2020 - 07:06 AM
Posted 05 July 2020 - 11:19 AM
Sounds unusual, they're normally just stamped plates. The belt slides over the top door post mounting, hence the round bar. Somebody hasn't stuck the cover in the wrong place? That'd explain you missing one elsewhere
Posted 05 July 2020 - 04:00 PM
I have the top ones that clip over the bar.I have no back ones for the C pillar.The bottom of the front belts has a cover which clips over the triangular belt mounted plate but only on one side.They are not essential but they finish off the job nicely.The bolt head on the face of the bins looks unfinished,am I missing something here/.thanks.Steve..
Posted 05 July 2020 - 08:57 PM
Posted 06 July 2020 - 09:00 AM
I have the top ones that clip over the bar.I have no back ones for the C pillar.The bottom of the front belts has a cover which clips over the triangular belt mounted plate but only on one side..... The bolt head on the face of the bins looks unfinished....
Plastic covers for the rear static belts were made in black, flint, & coffee.
I'm not sure if the bin anchor bolt heads ever had a plastic cap fitted but they would look better with them fitted.
http://www.somerford...age=page&id=137
I know the seat belt cover your on about but they're part of the seat belt & i've never seen them sold separately. Guess it will be a case of looking for a cheap second hand belt if only to pinch the cover off of it.
