2000 Sportspack Front Arch Issue
7 replies to this topic
#1 2000cooper
2000cooper
  • 32 posts
  • Local Club: Crewes Missiles
Posted 06 July 2020 - 11:18 AM
Afternoon all, advice and guidance required.... Had my sportspack restored, nut and bolt-a process that has taken a few years. Got it back last august and had a few issues, a snag list if you will which for the most part have been addressed, the car has done about 500 miles and I noticed a rubbing sound on full lock, it was only when i took the front arches off to be painted again (Stonechips, have since been PPF'd) I noticed the tyre has rubbed against the arch where the new front panel and wing meet. Car is fitted with hi-los but set to standard ride height, new rubber cones that are bedding in, could explain a drop in height and cause the rubbing issue?
#2 Tupers
Tupers
  • 4,105 posts
Posted 06 July 2020 - 11:23 AM
Do you know if the new front panel and wings were trimmed to clear 13” wheels like the factory did?
#3 2000cooper
2000cooper
  • 32 posts
Posted 06 July 2020 - 11:38 AM
Having spoken with the restorer they have a template for this and it was done
#4 RedRuby
RedRuby
  • 1,201 posts
  • Local Club: No
Posted 06 July 2020 - 11:57 AM
Has it had a new or replacement steering rack. I believe there is a special steering rack for sports pack models with limiters fitted . Also what wheels and tyres have you got as the offset may be allowing the wheels to sit further out.
#5 2000cooper
2000cooper
  • 32 posts
Posted 06 July 2020 - 12:31 PM
As far as i am aware its the same steering rack from new as issued by rover, running standard sportspack wheels and 175/50/13 tyres, just had a call to say there is possibly a template as mentioned above available from minispares as a guide of how much to modify to ensure clearance. Looking at older pictures of the car when it was being stripped and looking at it now there is a marked difference in clearance!
Appreciate the responses, its given me a few things to check on the car to see whether they could be applicable...
#6 Midas Mk1
Midas Mk1
  • 5,640 posts
  • Local Club: S.U.N.M.C
Posted 06 July 2020 - 05:05 PM
tie arms bent? Wrong castor willmove the wheel in the arch.
#7 nicklouse
  • 17,931 posts
Posted 06 July 2020 - 05:35 PM
sports pack cars did not run standard height but were raised slightly.
#8 2000cooper
2000cooper
  • 32 posts
Posted 07 July 2020 - 10:13 AM
Cheers for the responses, looking it to all the above as we speak!
