Exhaust Fit 1990 Mayfair
Best Answer duf72 , 19 July 2020 - 12:32 PM
Yeah, thought so, problem solved. Ta.
Go to the full post
4 replies to this topic
#1 duf72
duf72
  • 13 posts
Posted 19 July 2020 - 09:19 AM
I have just got round to fitting my Sportex centre exit pipe, however, when I removed old manifold. carb set up (single) is attached to manifold. New pipes do not have facility to attach carb assembly, so I have 5 ports, only 3 on new pipe. I assume I need some sort of adaptor, but what? Help!
Edited by duf72, 19 July 2020 - 09:23 AM.
#2 nicklouse
  • 19,066 posts
Posted 19 July 2020 - 09:27 AM
Sounds like you have bought an exhaust system with manifold (LCB or 3-1) so you will need an inlet manifold as well.
#3 cal844
cal844
  • 9,735 posts
  • Local Club: TFMOC
Posted 19 July 2020 - 11:42 AM
If you removed the cast type manifold you need the alloy inlet manifold
#4 duf72
duf72
  • 13 posts
Posted 19 July 2020 - 12:32 PM   Best Answer
#5 Algordo1100
Algordo1100
  • 774 posts
Posted 19 July 2020 - 05:07 PM
Apparently you can cut the cast manifold. It is not something I have tried myself. Especially since inlet manifolds are relatively cheap and plentiful.
In fact I have a spare you could have for free if you're near by.
