Clutch Pedal Depresses But Then Goes Hard?
Best Answer cal844 , 19 July 2020 - 10:37 PM
Make sure the plunger linkage moves freely in the casing. Go to the full post
14 replies to this topic
#1 shish_happens
shish_happens
  • 34 posts
Posted 19 July 2020 - 09:53 PM
Hi all,
I've been having problems with my clutch. It's had several new parts new master and slave, new flexihose as well as a second hand clutch and flywheel as I left mine uncovered outside and it rusted quite badly.
The clutch pedal depresses fine, and the plunger goes out of the slave however when the pedal is released the plunger doesn't go back into the slave and needs a proper hammering to get to go back in
From my understanding this would be a clutch/flywheel problem? The little plastic and metal cap is installed on the end of the flywheel, I doubt it's easy to install that incorrectly?
Any help appreciated. I'm dreading having to pull the engine for the 3rd time to do anything with the clutch
#2 Its a min
Its a min
  • 284 posts
Posted 19 July 2020 - 10:37 PM
Verto or non-verto? What year is your car?
#3 cal844
cal844
  • 9,640 posts
  • Local Club: TFMOC
Posted 19 July 2020 - 10:37 PM   Best Answer
#4 shish_happens
shish_happens
  • 34 posts
Posted 19 July 2020 - 10:53 PM
It's a verto early 90's 998
#5 shish_happens
shish_happens
  • 34 posts
Posted 19 July 2020 - 10:54 PM
I might have to give it another few smacks forwards and backwards with the hammer although I've done that before till I couldn't barely swing the hammer
#6 shish_happens
shish_happens
  • 34 posts
I might have to give it another few smacks forwards and backwards with the hammer although I've done that before till I couldn't barely swing it
#7 Its a min
Its a min
  • 284 posts
Posted 19 July 2020 - 11:02 PM
Have you made sure the release bearing is fitted to the plunger the right way round and that the clutch lever arm isn't broken/worn on the ball end?
#8 Dusky
Dusky
  • 5,322 posts
Posted 20 July 2020 - 08:15 AM
Bad flexi hose acting like a one way valve. To check open the bleeder after releasing the pedal.
#9 Ethel
  • 26,063 posts
Posted 20 July 2020 - 10:25 AM
Could be as Dusky suggests, the piston is more prone to stick on return too if it's been sat a while and the cylinder bore's got rusted or dry.
Open the bleed screw to check the hose then unbolt the slave test if it's  still stuck to eliminate the hydraulics altogether. Beware it will be under load from the clutch springs if it is the hydraulics holding it.
#10 shish_happens
shish_happens
  • 34 posts
Posted 20 July 2020 - 11:09 AM
It's a brand new flexihose and master and slave
#11 GraemeC
GraemeC
  • 7,440 posts
Posted 20 July 2020 - 12:34 PM
Disconnect the pushrod from the arm, then check the plunger is free in the wok.
Using a hammer isn't going to do anything any good!
#12 shish_happens
shish_happens
  • 34 posts
Posted 20 July 2020 - 01:52 PM
I'm trying to free up the plunger hitting it back and forth not just smacking the wok! I have to smack it back once I've pressed the clutch pedal
I'm bleeding the brakes soon so I'm hoping it's just a seized clutch?
#13 viz139
viz139
  • 682 posts
  • Local Club: Irish Mini Owners Club
Posted 20 July 2020 - 02:38 PM
First thing I would do is remove the slave cylinder and confirm that the problem is in the lever and not the hydrolisc. If its the lever remove the wok , dismantle and clean and grease all parts . You may free the lever by banging it but unless the car is to be used as a daily runner come next winter you will have the same problem again every time the car is left sitting for a period.
#14 shish_happens
shish_happens
  • 34 posts
Posted 20 July 2020 - 04:25 PM
Looks like its wok off time today then. The plunger doesnt budge and the hydraulics are fine
#15 shish_happens
shish_happens
  • 34 posts
Posted 20 July 2020 - 09:43 PM
I can confirm it was the plunger. It was rock solid. All free'd up and greased now
