Rear Backplates - Washers Between?
Best Answer GraemeC , 20 July 2020 - 11:30 AM
Sounds wrong to me.
There should be washers (or a distance piece) between the backplate and the handbrake cable retaining plate for the front bolt though
Go to the full post
2 replies to this topic
#1 no66
no66
  • 156 posts
  • Local Club: NMCC (Norsk Mini Cooper Club)
Posted 20 July 2020 - 11:26 AM
1972
When I dismantled the backplates off the rear radius arm, I pretty sure that the two front bolts had plain washer between the backplate and the radius arm. This means that there was a gap between the back plate and radius arm at the leading edge.  This was both sides and I'm pretty sure this is origianl.
Bolt>backplate>washer>radius arm>lock washer>nut.
The rear bolt had no washer (just the lock washer).
Is this right? Or should the backplates be against the radius arm mounting?
#2 GraemeC
GraemeC
  • 7,475 posts
Posted 20 July 2020 - 11:30 AM   Best Answer
Sounds wrong to me.
Edited by GraemeC, 20 July 2020 - 11:32 AM.
#3 no66
no66
  • 156 posts
Posted 20 July 2020 - 11:43 AM
Sounds wrong to me.
Just back from the workbench to say I had a brainfart!
Forgot the handbrake brackets and it all became clear! Thanks anyway
Edited by no66, 20 July 2020 - 01:14 PM.
