Removing A Stripped Reverse Light Switch
5 replies to this topic
#1 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 20 July 2020 - 01:55 PM
Hi everyone,
I recently stripped the reverse light switch inside the rod change selector housing, because I am an idiot. I was wondering what the best technique would be to remove it? Would it be a good idea to remove the bottom plate and then use some mole grips to try and turn out the switch?
Thanks,
Vinay
#2 nicklouse
  • 19,060 posts
Posted 20 July 2020 - 02:09 PM
well it depends on what you plan to do next.
i would remove the housing and then work on the bench to fix it.
#3 Vinay-RS
Vinay-RS
  • 2,115 posts
Posted 20 July 2020 - 02:22 PM
at the moment, I just want to get it out. I still need to get a new one from a motor spares place.
#4 nicklouse
  • 19,060 posts
Posted 20 July 2020 - 02:40 PM
Just keep turning it then so all the threads are pulled out and it will just pull out.
#5 GraemeC
GraemeC
  • 7,473 posts
Posted 20 July 2020 - 07:31 PM
The first thing to do is work out what’s stripped.
Brass vs aluminium - both soft - I’m not sure which would win, but I’d suspect brass.
#6 Spider
  • 15,859 posts
Posted 20 July 2020 - 07:55 PM
Yes, usually the Housing comes off second best.
I think you'd need to get a little brutal to get the old switch out, but just check to be sure, which part is stripped.
As a fix if the housing is stripped, you could get a second lock nut to fit up on the inside. It would be a pain to adjust, but it's not something that's done often.
