Cooper Mainstream Running Lean
7 replies to this topic
#1 beardylondon
beardylondon
  • 1,795 posts
Posted 21 July 2020 - 08:58 AM
Over lockdown I refurbed my head, did valve stem oil seals (which stopped it smoking), ground the valves back in, put it all back together. After some advice on here, as I wanted to keep it as original (and quiet) as poss, I kept the cast Cooper manifold, and used a Maniflow down pipe to connect to twinbox RC40. I kept the standard air filter and haven't touch the needle. Tappets are set to 12 thou.  It has brand new plugs (the correct BPR6ES ones from Minispares) and I set the timing and it runs a bit lean.
Could it be worth changing the needle?
Edited by beardylondon, 21 July 2020 - 09:02 AM.
#2 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 21 July 2020 - 09:03 AM
You may need to, What do the plugs look like? You may find the plugs look OK but in my experience minis like to run a little rich to be happy
#3 beardylondon
beardylondon
  • 1,795 posts
Posted 21 July 2020 - 09:45 AM
Thanks, plugs look like this
#4 jaysmini1983
jaysmini1983
  • 217 posts
  • Local Club: West Country Mini's
Posted 21 July 2020 - 11:19 AM
i would say its a nice golden colour, maybe a touch lean, just adjust the needle slighlty, 1/4 turn richer and take for a test run.
#5 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 21 July 2020 - 02:26 PM
Yup they need to be richer. Is the dashpot oil topped up?
#6 beardylondon
beardylondon
  • 1,795 posts
Posted 21 July 2020 - 07:59 PM
I thought the carb screw only adjusted idle, not mixture. Yeah I’m pretty sure I topped dash pot up, will double check.
#7 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 21 July 2020 - 08:25 PM
Mixture is adjusted overall, regulated by the needle. Give it a quarter turn (or 2 flats if on a HS carb) rich and try it first. If that doesn't work you need a richer needle (back off the mixture to where it is now).
Edited by cal844, 21 July 2020 - 08:26 PM.
#8 Dusky
Dusky
  • 5,322 posts
Posted 21 July 2020 - 08:38 PM
That looks almost perfect with ethanol fuel. The golden brown color is only favorable with non ethanol fuel.
