Short Fuel Hose From Solid Pipe To Fuel Pump
2 replies to this topic
#1 h9hpj
h9hpj
  • 42 posts
Posted 21 July 2020 - 10:13 AM
What Fuel line diameter from solid pipe to fuel pump? I have a kink in the very short original and need to change it. Any ideas? - The metal end has a slightly flared end and my 6mm pipe won't slide over. Is it slightly larger than the pump to carb hose?
#2 jaysmini1983
jaysmini1983
  • 217 posts
  • Local Club: West Country Mini's
Posted 21 July 2020 - 11:22 AM
did you warm the pipe in boiling water, it should be 6mm fuel hose.
#3 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 21 July 2020 - 02:24 PM
I use 6mm and heat it in a cup of boiling water so it's flexible.
I get away with 1/4 inch too but you need god quality jubilee clips
Edited by cal844, 21 July 2020 - 02:29 PM.
