Engine Rebuild!
11 replies to this topic
#1 Landyboy007
Landyboy007
  • 29 posts
Posted 22 July 2020 - 01:08 PM
Hi guys,
I need some help please on removing the main engine block from the heat box. I have removed everything and have whacked it with a hammer and still doesn’t shift. Could I have have a step by step guide? Or am I missing anything?
#2 MiniMadRacer
MiniMadRacer
  • 906 posts
Posted 22 July 2020 - 01:18 PM
Do you mean the gear box?
If so have you removed the clutch and flywheel and its housing
#3 johnv
johnv
  • 499 posts
  • Local Club: FDMC
Posted 22 July 2020 - 01:30 PM
Have you got all the nuts on the edges? There’s at least one tricky to find one
#4 nicklouse
  • 19,066 posts
Posted 22 July 2020 - 01:34 PM
Hi guys,
Sounds like you are missing a Haynes manual.
there are two bolts that are “hidden” behind the front plate.
#5 Landyboy007
Landyboy007
  • 29 posts
Posted 22 July 2020 - 02:27 PM
Yes Gear box and I have removed everything apart from one bolt which the head has now rounded, but surely it should lift one side?
Edited by Landyboy007, 22 July 2020 - 02:27 PM.
#6 Landyboy007
Landyboy007
  • 29 posts
Posted 22 July 2020 - 02:28 PM
I have removed every bolt apart from one which the head has now rounded..... but surely it should lift one side!?
#7 nicklouse
  • 19,066 posts
Posted 22 July 2020 - 02:35 PM
Not really.
#8 nicklouse
  • 19,066 posts
Posted 22 July 2020 - 02:42 PM
There are normally 10 bolts and 2 nuts that need removing. There can also be a nut and bolt through any hollow dowls fitted. Normally one but some one may have added a second items 6-9 in the image here
http://www.minispare...e.aspx?2~14~123
#9 johnv
johnv
  • 499 posts
  • Local Club: FDMC
Posted 22 July 2020 - 02:55 PM
Not really.
You'll bend/break something! It will need to come out
#10 Landyboy007
Landyboy007
  • 29 posts
Posted 22 July 2020 - 07:37 PM
[quote name="johnv" post="3658626" timestamp="1595429706"]
[quote name="nicklouse" post="3658619" timestamp="1595428524"][quote name="Landyboy007" post="3658617" timestamp="1595428126"]
[quote name="johnv" post="3658606" timestamp="1595424614"]
Have you got all the nuts on the edges? There’s at least one tricky to find one[/quote]
[/quote]Not really.[/quote]
You'll bend/break something! It will need to come out[/quote
So what’s the best way to remove it if the head as rounded? Can u grind it? But surely the bolt and thread will still stop it from coming out?
#11 cal844
cal844
  • 9,735 posts
  • Local Club: TFMOC
Posted 22 July 2020 - 09:56 PM
[quote name="Landyboy007" post="3658657" timestamp="1595446642"]
So what’s the best way to remove it if the head as rounded? Can u grind it? But surely the bolt and thread will still stop it from coming out?[/quote]
Use a 6 sided socket that's slightly undersized
#12 nicklouse
  • 19,066 posts
Posted 23 July 2020 - 09:49 AM
Why would it? Only one part is threaded. Remove the head and there is nothing holding it in place.
