Making Bonnet Or Body Holes
3 replies to this topic
#1 ian76
ian76
  • 10 posts
Posted 23 July 2020 - 02:53 PM
I did see the bonnet strap threads but this goes beyond that. my question is if I were to make holes in the bonnet for a strap or I have seen badges screwed on the sides. How do prevent that exposed metal hole area from the elements? I don’t want it rusting underneath where I can’t see. Does that make sense?
#2 johnR
johnR
  • 2,325 posts
Posted 23 July 2020 - 04:44 PM
If you paint any exposed metal you can reach and use a sealer (Hylomar?) on bolts/screws you should be OK. If you're making a hole into a box section you could spray paint or waxoil in it before you cover.
#3 ian76
ian76
  • 10 posts
Posted 23 July 2020 - 05:55 PM
Thank you johnR! Super helpful!
#4 Tornado99
Tornado99
  • 750 posts
Posted 26 July 2020 - 09:38 PM
Im using as spray product at call FluidFilm which is a lanolin base for automotive corrosion protection. It is generally used as undercoat and cavity sealing. Seems to stay where applied.
