Heater Valve Instalation
8 replies to this topic
#1 Fizzy G
Fizzy G
  • 14 posts
Posted 23 July 2020 - 08:27 PM
Could any one please help?
Is there any images on the correct installation of the heater valve inside the engine bay, is there any sequence as to which hose from the heater matrix it needs connecting to,
Thank you
#2 nicklouse
  • 19,063 posts
Posted 23 July 2020 - 09:23 PM
Depends which one you are fitting.
bolt to head and run hose from it.
#3 PACINO
PACINO
  • 821 posts
Posted 23 July 2020 - 09:24 PM
This valve is for SPI models, but I dont know your car.
Regards Luis
#4 Fizzy G
Fizzy G
  • 14 posts
Posted 24 July 2020 - 08:41 PM
Thanks Luis
My car is originally an SPI, but I have altered the hose configuration, thanks for the images, is that going at any preference to the two hoses from the heater matrix. Currently I have temporary installed it free from any brackets, also it seems close to the exhaust. will this affect the valve?
Thanks again for taking the time to reply
Andy
#5 Fizzy G
Fizzy G
  • 14 posts
Posted 24 July 2020 - 08:58 PM
Hi Nick
Thanks for the reply
I currently have it unsupported, can I ask will the heat from the exhaust compromise the workings internally?
I have no option to bolt to the head as it is a spi engine, will this effect if it hangs between the hose loosely also which pipe from the heater matrix is better or does it not matter
Thanks again
#6 Tds76
Tds76
  • 87 posts
Posted 24 July 2020 - 10:36 PM
On mine I did the matrix top pipe/hose to radiator bottom. Matrix lower is connected to the head via the valve.
#7 PACINO
PACINO
  • 821 posts
Posted 24 July 2020 - 11:07 PM
Hello Andy! The photo belongs to a friend's Mini but it is not a SPI model. He has installed that valve on a carburetor engine like mine, and he says it works very well. I think a couple of photos to see the configuration of you hoses would make it easier for the colleagues to help you.
Luis
#8 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 25 July 2020 - 09:51 AM
I made a small bracket between the end exhaust stud and the heater valve
#9 Fizzy G
Fizzy G
  • 14 posts
Posted 25 July 2020 - 07:31 PM
Thanks all
Every bit of information helps
Kind regards all
