Oversize Crank Bearing Question
4 replies to this topic
#1 duffdub
duffdub
  • 47 posts
Posted 25 July 2020 - 02:54 AM
I dropped my A+ 1275 crank off at the machine shop to be reground. The main journals measure at about 2.010”. I’ve read they can measure 2.005” to 2.010”. Why is this this? Wouldn’t that mean new oversize bearings may not fit? Or does the 0.005 difference not matter? Hope my question makes sense.
#2 GraemeC
GraemeC
  • 7,476 posts
Posted 25 July 2020 - 06:06 AM
2.005”-2.010” is the dimension with a given tolerance - if it was an exact figure it would be harder to achieve and hence MUCH more expensive.
If it is being reground, the machine shop will advise the bearing size needed.
#3 duffdub
duffdub
  • 47 posts
Posted 25 July 2020 - 06:28 AM
Okay thank you
#4 Spider
  • 15,878 posts
Posted 25 July 2020 - 07:01 AM
Might have the decimal point in the wrong place there guys.
The Std Mains on a pre-A+ 1275 are 2.001 to 2.0025".
A+ 1275 is 2.0011 to 2.0017".
#5 duffdub
duffdub
  • 47 posts
Posted 25 July 2020 - 07:40 AM
Oh I left some 0’s out. Thank you for the correction
