Idle Speed Is Up And Down.
3 replies to this topic
#1 slowy
slowy
  • 71 posts
Posted 25 July 2020 - 02:47 PM
Hi guys the idle speed goes up and down, is it fuel or ignition. Engine is 1293 sw5 cam hiff44 carbon big value head .thanks for any advice.
#2 PACINO
PACINO
  • 821 posts
Posted 25 July 2020 - 06:05 PM
Have you got oil under bottom top Hif44 carb? Check it!
Luis
#3 cal844
cal844
  • 9,735 posts
  • Local Club: TFMOC
Posted 25 July 2020 - 06:40 PM
Check the vacuum advance pipe and elbows for perishing. Also check for air leaks around the manifold and carb
#4 slowy
slowy
  • 71 posts
Posted 25 July 2020 - 08:07 PM
thanks for replying, will check oil in carb. Then go through inlet for leaks.
