Which Diff
13 replies to this topic
#1 Sunbeam
Sunbeam
  • 11 posts
Posted 25 July 2020 - 06:29 PM
Hi all, can anyone advise me as to what diff ratio to use. I’m fitting a 998 a plus to a mk1 . I’m going to fit a stage 1 upgrade, hs4 carb , maniflow exhaust and port the valves. I want to keep the 10” wheels and fit 7.5” discs. Any advice appreciated.
#2 nicklouse
  • 19,055 posts
Posted 25 July 2020 - 06:35 PM
what is in there now?
#3 Sunbeam
Sunbeam
  • 11 posts
Posted 25 July 2020 - 06:40 PM
850
#4 Spider
  • 15,837 posts
Posted 25 July 2020 - 08:08 PM
I'd suggest a 3.44 or if you don't do much motor way driving, a 3.6.
#5 Cooperman
  • 23,564 posts
Posted 25 July 2020 - 08:29 PM
+1 on the 3.44:1.
#6 Sunbeam
Sunbeam
  • 11 posts
Posted 26 July 2020 - 08:18 AM
Thanks for the info. Any idea on what speedo drives I would need or where to find out? Thanks again.
#7 nicklouse
  • 19,055 posts
Posted 26 July 2020 - 08:51 AM
Read this http://www.guess-wor...Tech/speedo.htm
Then pit the info into this http://www.guess-wor.../Tech/ratio.htm
And it will tell you what is needed.
#8 Spider
  • 15,837 posts
Posted 26 July 2020 - 09:10 AM
I think you'd have a 3.7: 1 ratio now, with a 6:17 Speedo Drive.
For a move to a 3.44 FD, you'd likely go to a 7:17 Speedo Drive
For a move to a 3.6 FD, you'd likely go to a 7:18 Speedo Drive
#9 unburntfuelinthemorning
  • 2,003 posts
Posted 26 July 2020 - 01:12 PM
For a 998, 3.44:1 is a great all rounder but 3.76:1 is good fun and it'll still do 70mph all day.  Depends on your priorities.
#10 Minigman
Minigman
  • 803 posts
Posted 26 July 2020 - 02:13 PM
3.76 in a 998 is great but will be higher revving and noisier at motorway speeds. If you want something that accelerates well and is fun to drive on the B roads then go with 3.76. If you want something to munch miles at 70mph 3.76 can be wearing so 3.1 maybe better. 3.44 is a good all rounder. All depends what you want from the car.
#11 goudoogje
goudoogje
  • Just Joined
  • 94 posts
Posted 27 July 2020 - 01:49 PM
I think this is very personal, i personally don't like anything above 3.1, because of the noise on the highway.
#12 Minigman
Minigman
  • 803 posts
Posted 27 July 2020 - 06:40 PM
But any ratio higher than 3.1 kills 998 acceleration. Even 3.1 takes the edge off quite a bit. Better with a lower 3.44 or even lower for acceleration but it does depend what the use is.
Edited by Minigman, 27 July 2020 - 06:44 PM.
#13 Cooperman
  • 23,564 posts
Posted 27 July 2020 - 07:26 PM
To put some perspective here, the original 850, the 997 & 998 Coopers all had 3.76:1.
The original 1071 'S' had a 3.76, whilst the 1275 'S' had the 3.44:1. The 'S's had a higher 1st, second & 3rd gear though which needed a fairly low FDR in order to get a really good 0 - 60 time.
It does need to be remembered that we are talking about an over-60 year old basic design here and the Mini is 'retro' driving at its best. Don't be afraid to rev them a bit, it's what they were always intended for. In the '60's we used to cruise our 998 Coopers and 'S's at 80+ mph, which was usually over 5000 rpm. To think, we did this all day long on a journey. That is what classic car driving is about.
#14 Sunbeam
Sunbeam
  • 11 posts
Posted 28 July 2020 - 06:39 PM
Thanks all, gives me something to think about!
