Car Failed Emissions
14 replies to this topic
#1 minicooperr
minicooperr
  • 277 posts
Posted 28 July 2020 - 03:57 PM
Car has failed on its emissions at well over what the spec is what do I do
#2 nicklouse
  • 19,060 posts
Posted 28 July 2020 - 03:59 PM
what is it? what spec? what were the results?
#3 johnR
johnR
  • 2,322 posts
Posted 28 July 2020 - 04:58 PM
Change the garage you use for MOT to start with - mine would adjust the emissions and re-test it.
#4 beardylondon
beardylondon
  • 1,795 posts
Posted 28 July 2020 - 05:18 PM
I heard that dodgy garages don't warm the car up for long enough to make older cars fail and then try and buy the failures cheap, as they say it's too expensive to fix. Doesn't really apply to minis, but even so.
#5 minicooperr
minicooperr
  • 277 posts
Posted 28 July 2020 - 05:38 PM
It’s not particularly dodgy garage as it was just a kwik fit as I’ve only just moved to the area (Cheltenham) and was unsure on where to go, it passed the one half of the emissions but failed on the co part of it, I’m guessing I just need to turn the fuel mixture down?
Edited by minicooperr, 28 July 2020 - 05:51 PM.
#6 cal844
cal844
  • 9,734 posts
  • Local Club: TFMOC
Posted 28 July 2020 - 07:02 PM
Change your garage, never use kwik fit
#7 beardylondon
beardylondon
  • 1,795 posts
Posted 28 July 2020 - 07:09 PM
Kwik Fit = dodgy, as Cal says, change garage! My local Kwik Fit kept failing my rear brakes on my Mk1, as their machine was too sensitive, I took it to a local independent and it has passed every year since.
#8 Algordo1100
Algordo1100
  • 774 posts
Posted 28 July 2020 - 07:19 PM
Yea, kwik-fit are not suitable for our little cars. I needed a quick tracking check last year and the guy failed to even get the machine on to my 12s.
Is this your Spi motor running a HIF? Was the test done engine specific or car specific? I'm not 100% but do they do it off engine number? So the car is older and would have a higher CO limit but the engine is newer and has lower limits for an ECU controlled fuel injection
Edited by Algordo1100, 28 July 2020 - 07:23 PM.
#9 minicooperr
minicooperr
  • 277 posts
Posted 28 July 2020 - 07:28 PM
It is a spi with a hif44 on it yes, the limit was 3.5 I think, so unsure if that’s the limit for the engine or the car, but I assume it’s the car, I’m hoping I would just be able to turn it down to lean it out and take it back and hopefully that will make to clear
#10 nicklouse
  • 19,060 posts
Posted 28 July 2020 - 07:30 PM
again
#11 minicooperr
minicooperr
  • 277 posts
Posted 28 July 2020 - 07:35 PM
It’s a 1275cc spi engine with a hiff44 on it in a 1989 car, the co limit was 3.5 and the car was getting 6.5 on the results
#12 Algordo1100
Algordo1100
  • 774 posts
Posted 28 July 2020 - 07:36 PM
Owners manual for my SPI says 0.5% max (hot) at tailpipe. That's the manufacturer though, not the ministry.
#13 minicooperr
minicooperr
  • 277 posts
Posted 28 July 2020 - 07:55 PM
Okay but my car is a 1989 so I assume it’s being tested to 3.5 which is the car not the engine
#14 imack
imack
  • 2,382 posts
Posted 28 July 2020 - 08:45 PM
Will be tested on the age of the car in your case. Assuming the cars well maintained eg clean air filter etc then just adjust the carb. Long time since I've adjusted an HIF but there should be an adjustment screw in the side of the carb body. If it's never been adjusted (unlikely)it may have a blanking plug covering it that needs digging out first.
Edited by imack, 28 July 2020 - 08:46 PM.
#15 minicooperr
minicooperr
  • 277 posts
Posted 29 July 2020 - 04:13 PM
I managed to adjust myself and got it passed, wasn’t ideal but a pass is a pass cheers all ??
