Servo Gasket And Rocker Cover
Best Answer richmondclassicsnorthwales , 29 July 2020 - 09:21 AM
NAM8570 is the small seal, just a rubber ring needed for the join.
As for the T Bars, tighten up well, I some times give them a further little tweak with a set of mole grips. Keep an eye on them periodically to ensure no oil leaks when the gasket compresses a little
Pressure of 3 to 4 lbft required for tightening the T Bars as a guide
Go to the full post
Posted 29 July 2020 - 08:21 AM
Also, I have put a nice shinny rocker cover on with the cork gasket. The cover is secured with the t-bars that are just done up by hand. Assume you basically do them up as tight as you can? At first I hadn’t done so and oil seeped through (when doing an oil change).
Posted 29 July 2020 - 09:21 AM Best Answer
Posted 29 July 2020 - 09:55 AM
Thanks very much. I have the seal so will fit that. Also thanks for confirming the T-bat torque.
