Fast Idle
5 replies to this topic
#1 johnR
johnR
  • 2,322 posts
Posted 29 July 2020 - 11:09 AM
I've finally found the correct ratio of mixture and advance to make my car go well, but the idle speed is a little high. The adjuster isn't even touching the choke quadrant so I can't lower it that way. When I was 'Vizarding the throttle spindle I noticed a small hole drilled through the butterfly - is it necessary? (HS4) - would soldering it up lower the revs?
#2 robert.hedges
robert.hedges
  • 53 posts
Posted 31 July 2020 - 06:25 PM
Yes. Also if you've fitted new spindle bushes check the flow past they need an extra tap once you've refitted the throttle disc
#3 Chris1275gt
Chris1275gt
  • 1,052 posts
Posted 31 July 2020 - 07:35 PM
This was the advice given to me by Moke on my HS4~
It's there to reduce NOX on the over-run.
Solder it up.
So I just changed the butterfly to a plain one and cured my problem and has worked fine since.
#4 sonscar
sonscar
  • 3,255 posts
Posted 01 August 2020 - 08:41 AM
If you have had the butterfly out is it the right way around as they are slightly tapered,also they take a bit of centerings causing them to bind.If not ignore this.Steve..
#5 johnR
johnR
  • 2,322 posts
Posted 02 August 2020 - 04:18 PM
Thanks all, will solder it up.
#6 83mini1000special.90
    Just On Tickover
  • 9 posts
Posted 09 August 2020 - 10:57 AM
i have the same problem with my idle.its always too high when warm.
i thought the small hole is for air on idling?
there is another type with a valve in the butterfly. i had this before and changed out for the butterfly with just the small hole
