Water Temp Sensor
24 replies to this topic
#16 madaboutcherry
madaboutcherry
  • 539 posts
  • Local Club: no
Posted 03 August 2020 - 10:15 AM
Only yesterday I made a spacer block for the thermostat cover and incorporated a separate sender in that. If I remember today, I'll snap off a couple of photos.
that's brilliant Moke, i'll get meself a sandwich plate. what top radiator bracket are you using?
#17 Spider
  • 13,901 posts
Posted 03 August 2020 - 10:37 AM
Cheers for that. I did make a bit of an error with it, in that the sender is a bit close to the hose, but it all fits.
The top bracket is a custom one, infact, the whole radiator shroud is.
#18 I hate Brian
I hate Brian
  • 770 posts
Posted 03 August 2020 - 11:54 AM
Hi Moke what head you got there as wondering why you didn't use the thermostat housing hole ? looks threaded
#19 I hate Brian
I hate Brian
  • 770 posts
Posted 03 August 2020 - 11:56 AM
Would you make me one with a 5/8ths temp sender  ;D  ;D  ;D  ;D  ;D  ;D  (original sender) as I want to convert from three clock to a centre and I have an SPI so no tapped or drilled hole
#20 Spider
  • 13,901 posts
Posted 04 August 2020 - 07:56 AM
The head on this engine is from an MPI, which don't have a sender hole. I drill & tap these before fitting to take the standard sender. I will be using the hole that I've put in the head for the Temp Gauge, and the other is for an ECU.
I'll drop you a PM.
#21 richmondclassicsnorthwales
  • 942 posts
Posted 04 August 2020 - 10:54 AM
Nice attention to detail !
#22 madaboutcherry
madaboutcherry
  • 539 posts
  • Local Club: no
Posted 11 September 2020 - 11:17 AM
another question. the s/c wire that goes to the crank position sensor is a bit too short to reach so i thought i'd extend the wires by about 10cms. but when i cut the new loom i discovered the wires are shielded, is it critical to replace such a short length with shielded cable or ordinary cable do?
#23 gazza82
gazza82
  • 2,916 posts
  • Local Club: TMF+
Posted 11 September 2020 - 01:25 PM
I would have thought if it's shielded there is a reason for it so the extension should be or stray signals might get through.
#24 tmsmini
tmsmini
  • 709 posts
  • Local Club: MOASF
Posted 11 September 2020 - 06:41 PM
This is my variation on the thermostat sandwich. The engine is an MPi block and head with a side mounted radiator, similar to the later JDM SPi versions.
The thermostat elbow is the JDM SPi version with the unique short hose.
One sensor is for the gauge and the other for the SC Delta ECU.
On this engine, the top bracket is a standard shaped piece with standoffs underneath to bring it to the height of the sandwich plate.
The sandwich is drilled for NPT with the appropriate adapter for each sensor.
#25 tmsmini
tmsmini
  • 709 posts
  • Local Club: MOASF
Posted 14 September 2020 - 10:30 PM
Here is another configuration we are using with a custom top bracket.
The other picture shows the routing of the crank sensor wire and other loom components on that side of the engine. The connector is behind/under the loom.
