Help Me Kernow Cooper - You’Re My Only Hope
7 replies to this topic
#1 steeley
steeley
  • Just Joined
  • 623 posts
Posted 04 August 2020 - 05:23 AM
I am open to help from others ;-)
I have nearly finished my mini apartfrom one electrical problem
Hazards work fine but when I indicate all 4 flash
I have checked and double and triple checked all connections
I have changed hazard switch, flasher unit and tried another set of stalks which I had
None of this helps
If I put a bulb in interior light it blows bulb or fuse
I have 12v at light when on and 0v when off
Am I missing something obvious if not where would you start
Edited by steeley, 04 August 2020 - 05:25 AM.
#2 johnR
johnR
  • 2,244 posts
Posted 04 August 2020 - 10:06 AM
Use the Force, steeley, use the Force!
Edited by johnR, 04 August 2020 - 10:07 AM.
#3 GraemeC
GraemeC
  • 7,314 posts
Posted 04 August 2020 - 10:40 AM
You should have 12V at the interior light all the time on the purple/orange wire.- it is switched on/off by switching the earth on the purple/white wire.
The switch on the light should have three positions:
1) no connection to earth
2) permanent connection to earth
3) connected to earth via door switches
The purple/orange is connected to the same fuse as the purple orange that supplies power to the hazard relay
Edited by GraemeC, 04 August 2020 - 10:45 AM.
#4 GraemeC
GraemeC
  • 7,314 posts
Posted 04 August 2020 - 10:51 AM
Post a picture of your hazard switch wiring, and the wiring at both of the flasher units.
#5 Ethel
  • 25,414 posts
Posted 04 August 2020 - 05:11 PM
Mini interior lights are experts at shorting, lots of bits of bare metal. Notice you also had a horn topic going - the horn & headlamp flasher share volts with the interior light & it's not unknown for the wires on the column stalk to get detached.
The only place the L+R indicators should  connect is via the dash warning light.
Is it a centre speedo? Try pulling the bulb holder out of the casing.
Indicators are ignition dependent, hazards are permanent - turning the ignition on/off with one then the other running could give you a clue. Poor earthing points could link L to R instead, but should affect the brightness & flash rate as there'd be connected in series
#6 steeley
steeley
  • Just Joined
  • 623 posts
Posted 06 August 2020 - 05:15 AM
It Won’t get the better of me
I’ve bought one of these
#7 I hate Brian
I hate Brian
  • 770 posts
Posted 06 August 2020 - 05:56 AM
Great bit of kit I used mine for the first the other day,makes life a lot easier for fault finding
#8 steeley
steeley
  • Just Joined
  • 623 posts
Posted 06 August 2020 - 06:06 AM
That’s what I’m hoping as I have tomorrow off work I am hopefully gonna nail the sucker
