Are these worth fitting ??
Rear Oil Pick Up Pipe Filter / Trap In The Gearbox
Posted 04 August 2020 - 04:50 PM
Posted 04 August 2020 - 05:02 PM
Posted 04 August 2020 - 05:19 PM
More clarity needed. But if as above. A must.
Posted 05 August 2020 - 06:47 AM
Posted 05 August 2020 - 07:11 AM
A magnetic filter/trap.
Mixed feelings on these - if they do pick up a decent amount of swarf then they effectively block the oil passage off.
However, cleaned regularly they probably do a reasonable job of helping the oil pump not ingest stuff, but they are in a sod of a place to remove for cleaning.
You can get the ones without the gauze which I feel are slightly better - I don't see what purpose that serves here.
Posted 05 August 2020 - 05:09 PM
Posted 05 August 2020 - 05:33 PM
I've got the one without the gauge and modified a 'gold's sump plug with the extra strong magnet to fit. It probably collects 1/3 of the amount of debris that the gold sump plug collects. I change the oil every 1000 miles, removing that rear plug involves removing the drive shaft to gain access to the plug.
imack how much of a pain is to do ? is it worth it ?
Posted 05 August 2020 - 06:47 PM
