Clubman Radiator Mounts?
Posted 04 August 2020 - 07:19 PM
Should be the correct top bracket but not sure about the lower one? This is from round nose mini and make the rad lean in at the bottom. The cowl is also from round nose mini. Can’t seem to find any info. Mini spares site shows an early split cowl but this is up to 1974. My car is 78. Anyone got any ideas what I’m missing here?
D4B5FD1F-DE95-4F18-900C-66ABF467CA80.jpeg 29.21K 14 downloads
F9A8F5DE-C20A-43CC-B33C-C71917BBAB3F.jpeg 33.47K 11 downloads 319E7F08-2B61-4C91-BF48-9F813F6CFC69.jpeg 32.12K 6 downloads
Posted 04 August 2020 - 07:29 PM
There were different upper and lower brackets for the clubman, as well as thicker fan spacer.
for a one piece shroud you need this lower bracket:
http://www.somerford...roducts_id=5940
Edited by GraemeC, 04 August 2020 - 07:33 PM.
Posted 04 August 2020 - 07:31 PM
Ahhhh there are many different lower mounts. I am aware of at least 3 that fit like the later versions and then there are the very early ones that are totally different.
Posted 05 August 2020 - 07:56 AM
Posted 05 August 2020 - 11:11 AM
i think you've got the bottom mount the wrong way around.
Posted 05 August 2020 - 11:16 AM
Looks like the captive nut is towards the diff, so its correct.
Edited by GraemeC, 05 August 2020 - 11:16 AM.
Posted 05 August 2020 - 11:18 AM
yup, i've just checked, your's is correct.
Posted 05 August 2020 - 09:17 PM
The 1275 GT has a 1275 top bracket and is actually unique to that model. It's similar to the Cooper S one, but put the Radiator a bit further out from the engine.
There's 6 lower brackets I've found (that are used with the 2 piece cowlings), all different and there's 3 lower Cowlings (with the 2 piece types) also having different off-sets on the bracket.
Posted 06 August 2020 - 10:07 AM
But he has the one piece cowling
