Hi All
I have a HI Low system (just fitted to the car with Gaz shocks, the issue is that when you jack up the car, the HI LOs come apart? so if you where to change a tire, there could be a potential issue if it does not all drop in together when lowering the car off the jack... I hope this makes sense?
any help/advise welcome
(the Gaz shocks are GTO 2022 for a standard height (rear set-up))
many thanks in advance
John
Edited by neet street, 09 August 2020 - 02:24 PM.
