Dumb Question About Socket Wrench Sizes
23 replies to this topic
#16 surfblue
surfblue
  • 1,829 posts
Posted 16 September 2020 - 09:21 PM
Got a big Draper 1/2" socket set that I must have had 20 + years covers a multitude of AF and MM sizes, great quality used and abused on everything.
Also have a 1/4" drive B&Q own brand kit, cheapish but great selection of sockets and torx / allen bits, only had to replace 1 10mm socket which broke and the ratchet itself over much use.
I have a variety of random deep sockets, 3/8 sockets with adapters, spline sockets bought specifically for various jobs on more modern cars.
I really fancy this Teng tools kit as an all purpose 3/8" set, maybe I'll treat myself.
 https://www.ebay.co....LgAAOSwoJhdsvGc
#17 Icey
Icey
  • 1,584 posts
I used 1/2" drive for years (good quality set) and never had too many problems but then I bought a 3/8" drive set about three or four years ago and it was a revelation
Same here. Mostly because I started on more modern vehicles which seem to have every fastener wound to a gazillion torques. Now I tend to buy new sockets in 3/8" drive if I need something and then add smaller or larger later if needed. For example, hex-drive sockets - I started with those in 3/8" drive but needed a larger size for the crank pulley (as I have the extended one for a trigger wheel) so bought a 1/2" drive set.
I do have a 1" drive breaker bar and a couple of sockets that I inhereted. I think my Dad used them on his Landy, and as I have one they'll stay in the toolbox! I also have a few weird sizes and a set of Whitworth sockets for the same reason (including some box-spanners).
#18 And again
And again
  • Just Joined
  • 47 posts
Posted 16 September 2020 - 10:31 PM
I second the Halfords pro set covers everything and lifetime guarantee I’ve had mine 20+years only needed to have 1/4 ratchet replaced with no quibble or receipt needed as it’s all stamped up Halfords
Edited by And again, 16 September 2020 - 10:31 PM.
#19 nicklouse
  • 19,055 posts
Posted 16 September 2020 - 10:57 PM
3/8" isn't much cop on very tight bolts.
Never had any issues other than the big nuts on the Mini. That is anything over the size of the sockets in the set.
#20 nicklouse
  • 19,055 posts
Posted 16 September 2020 - 11:00 PM
I used 1/2" drive for years (good quality set) and never had too many problems but then I bought a 3/8" drive set about three or four years ago and it was a revelation;
Agreed.
#21 Ethel
  • 26,786 posts
Posted 16 September 2020 - 11:01 PM
I think you'd struggle with a 3/8" ratchet on some of the bigger fittings & a 1/2" torque wrench is needed to cover the fasteners where using one really matters.
But you may well find a mixed set that's better value.
#22 nicklouse
  • 19,055 posts
Posted 16 September 2020 - 11:02 PM
As MrBounce says - you can get carried away.......
Very easily.
Edited by nicklouse, 16 September 2020 - 11:38 PM.
#23 Maccmike8
Maccmike8
  • 1,101 posts
Posted 20 September 2020 - 10:31 AM
Ive got all all 3 and rarely use 1/4.
3/8 is my automatic go to.
#24 Cooper Mac
Cooper Mac
  • 222 posts
Posted 21 September 2020 - 08:27 AM
I've got 1/4, 3/8, 1/2 and 3/4 for various jobs on various cars, but for the strip and rebuild of the Cooper, 95% of it has been done with 3/8 sockets, ratchets and extensions etc.
I do find that the 3/8 stuff is small enough to get in tight spots, but also big enough to get most stubbon bolts undone! I have gone over to using 6 point (sided) sockets now, as they are less likely to slip on tight and / or corroded heads.
As always, buy the best you can afford at the time, and it should last your lifetime!
