Twin Su Carbs
Best Answer steeley , 16 August 2020 - 06:01 AM
Not a lot of benefit apart from looking cool then
I think I’ll still get and fit a set though Go to the full post
21 replies to this topic
#16 johnR
johnR
  • 2,244 posts
Posted 19 August 2020 - 08:59 PM
Looking around for a set, lots of different types - aud69 ,aud327 etc listing for mini and mg etc what would be the best type to buy for a std 998
Isn't the only difference the angle of the floatbowl? I think mine were Midget ones, then I just changed the coloured insert that sets the angle to the Mini type.
#17 steeley
steeley
  • Just Joined
  • 623 posts
Posted 20 August 2020 - 06:21 AM
I think I have found a set at a reasonable price
I am running std exhaust, manifold and pea shooter exhaust
What exhaust manifold will work (obviously 3 branch) but what options do I have or do I change whole exhaust
#18 Minigman
Minigman
  • 779 posts
Posted 20 August 2020 - 12:34 PM
The Maniflow freeflow manifold and their twin box exhaust is a good choice. But exhaust etc is personal choice. The RC40 is very popular and works well.
#19 Cooperman
  • 23,036 posts
Posted 20 August 2020 - 09:34 PM
For a 998 the Maniflow 3-into-1 manifold with a single box is fine. Pipe diameter should be 1.625" diameter, as the original Mini Cooper 998.
On the subject ot twin carbs, my personal feeling is that a pair of HS2's on a 998 with a well-flowed head and a good exhaust will be more efficient than a single 1.5" carb. The inlet manifold for the twins needs to be cleaned up with the internal steps and sharp edges removed. I can't quantify the advantage, but better mid-range seems likely as well as more top-end power. Two individual chokes feeding two inlet tracts seems logical, but the original BMC inlet manifold might be the weak link. There are better inlet manifolds for twins, or the BMC one can be improved considerably. I found an old 'Torquemaster' alloy inlet manifold recently with a pair of H4's in need of rebuilding on it. I might fit this to my 1990 Cooper 1330 road-rally car which currently has an HIF44.
#20 steeley
steeley
  • Just Joined
  • 623 posts
Posted 21 August 2020 - 06:11 AM
Just bought these
https://www.ebay.co....tm/293684529363
Another project to keep me busy
They’ll take a bit of work but a lot cheaper than a new set and more of a challenge,
it’s nice to buy new bits but more satisfying to refurb old parts and refit
All twin carb experts get ready for the questions
#21 johnv
johnv
  • 494 posts
  • Local Club: FDMC
Posted 21 August 2020 - 01:17 PM
You'll need to get a mini manifold / heat shield and the 30° float camber washers then you're good to go..
Edited by johnv, 21 August 2020 - 01:17 PM.
#22 steeley
steeley
  • Just Joined
  • 623 posts
Posted 21 August 2020 - 06:12 PM
Thanks for the heads up
