Rover Mini Cooper Mpi - 10 Day Restoration
#16
Posted 26 August 2020 - 08:53 AM
#17
Posted 26 August 2020 - 11:58 AM
You need more plug welds on the front wings, the number shown in the photos is nowhere near enough to make it strong enough in the event of an accident.
I assume any advice is not gonna help the OP as I think the vehicle is now finished and in paint. I think this thread is a quick reference to document the 10 day build timeframe.
#18
Posted 26 August 2020 - 12:41 PM
#19
Posted 26 August 2020 - 12:51 PM
#20
Posted 26 August 2020 - 01:37 PM
#21
Posted 26 August 2020 - 03:46 PM
What was the process for the scuttle to wing joint? Was this spot welded from behind and then seam sealed with tiger seal etc from the front? Same Q for the front panel to wing joint?
That’s right, it was tricky getting in there but the wings are puddle welded to the scuttle and front panel then tiger sealed from the outside. We used a proper seam sealer from inside though
#22
Posted 26 August 2020 - 05:57 PM
#23
Posted 26 August 2020 - 07:40 PM
No offence but the plug welds look weak upon zooming in on image. Not enough heat or no gas. Either way nice work especially working to a deadline.There’s the same number of welds that were originally used. Plug welds are also quite a bit stronger than the original spot welds
#24
Posted 26 August 2020 - 09:35 PM
#25
Posted 27 August 2020 - 07:09 AM
I'm pretty confident the welds will hold. We did quite a few test welds beforehand and they were binding very well. Time will tell I guess!
This is the first time I've restored a mini so go easy on me!
#26
Posted 27 August 2020 - 08:32 AM
#27
Posted 27 August 2020 - 02:39 PM
#28
Posted 27 August 2020 - 03:11 PM
Looks good, you're not hanging about :)
#29
Posted 27 August 2020 - 04:22 PM
#30
Posted 27 August 2020 - 08:30 PM
