Fitting New Metal Front Number Plate
5 replies to this topic
#1 Shaunaw30
Shaunaw30
  • 20 posts
Posted 29 August 2020 - 09:47 PM
looking for some advice..... how would you fit a new metal number plate to the front of an MPI mini? would you use double sided foam sticky tape or would you drill holes in the number plate and screw through?
wondering what the best look would be??
Shaun
#2 Quinlan minor
Quinlan minor
  • 1,388 posts
Posted 29 August 2020 - 10:37 PM
Tape is the best look, in my opinion.
#3 RustyAutoCityE
RustyAutoCityE
  • 320 posts
Posted 30 August 2020 - 07:14 AM
Screws for OEM look, Pads for a clean look.
Metal plates for an MPI are not an OEM look, so you can go what ever way you prefere (which of course you can for plastic plates too!).
Maybe try pads first, and if you don't like it go for screws?
If you do use pads, make sure you use good quality ones and clean/de-grease the mounting points well.
Don't want to lose them when your out and about enjoying the car.
#4 Bobbins
Bobbins
  • 1,526 posts
Posted 30 August 2020 - 08:39 AM
My ‘98 has metal number plates. I remounted the front plastic plate with stainless c/sunk screws to give some support then used sticky pads to mount the pressed plate over the original plastic plate.
#5 Midas Mk1
Midas Mk1
  • 5,853 posts
  • Local Club: S.U.N.M.C
Posted 30 August 2020 - 10:31 AM
Front plate bolts, there’s little surface area for the pads, and if you drive your Mini as intended it’ll fall off.
Rear plates 3m vhb tape :thumbsup:
#6 Shaunaw30
Shaunaw30
  • 20 posts
Posted 31 August 2020 - 11:38 AM
Thanks guys
