Check Strap Seals
Best Answer mini-mad-mark , 04 September 2020 - 08:21 PM
Better picture with the door seal pulled out of the way - its a bit deformed/squashed but I'm guessing its original so to be expected at 30 years old
It also seems to be made of quite stiff rubber rather than a softer closed cell foam type that I was expecting
Go to the full post
12 replies to this topic
#1 leepol83
leepol83
  • 1,744 posts
Posted 30 August 2020 - 12:07 PM
Hi all quick one again, can anyone show me how these closed cell foam check strap seals go, I think I get it but there’s a hole in them for something ? Not sure what and are they handed ?
Thanks ?
#2 richmondclassicsnorthwales
  • 942 posts
Posted 01 September 2020 - 03:24 PM
Yes they are sided.
CGE 10038 is the RH side,  CGE10039 is the LH
The hole is for the check strap to go through. They are normally split as I think some people seemed to be struggling and wondering how to fit them
Solution was to take away the split pin and extract the clevis pin, leaving the the check strap free.
#3 mini-mad-mark
mini-mad-mark
  • 703 posts
  • Local Club: northants wot no brakes
Posted 01 September 2020 - 08:44 PM
Do you mean a (small) hole apart from the obvious large one for the actual check strap - sounds too obvious to ask what that hole is for? Especially as you titled your post "check strap seal" so I'm assuming you know what the check strap is (its the metal bar thingy that is attached to the door and comes out of the A pillar to stop the door opening too far, just in case you don't)
If so my mini has a plastic peg just above the checkstrap - looks like it presses into the A pillar but not sure what it does (think they are original)
Assume there would have been a small hole for that peg if this is an original thing - maybe just a bodge on my mini.... O_O
I'll try to remember to get a picture tomorrow
#4 sonscar
sonscar
  • 2,724 posts
Posted 01 September 2020 - 10:18 PM
Mine originally had rubber seals which were retained by the same plastic peg.I guess the foam seals were just copied from this.Steve..
#5 Floyd kraemer
Floyd kraemer
  • 26 posts
Posted 02 September 2020 - 07:35 AM
I think it also depends on the year of your Mini.
My 1972 Mini has two holes in the seal. One is for the check strap and one for the interior light switch. The later ones only have a check strap hole.
I couldn’t find original two hole versions when I rebuilt mine, so ended up modifying later ones. I have some photos somewhere.
The two hole versions were glued onto the hinge panel rather than held on with a peg. Not a great design!!
#6 Tornado99
Tornado99
  • 750 posts
Posted 03 September 2020 - 05:11 PM
Plastic peg referred to above is the interior light switch to trigger it on when either side door is opened, assuming your lamp is set to come on with door opening (there's a slider switch on my lamp to set this) and bulb is good.
#7 leepol83
leepol83
  • 1,744 posts
Posted 03 September 2020 - 07:22 PM
Thanks all yes I’m asking about the small hole at the top of the check strap seal it’s tiny and in the foam seal itself there is a hole to match it too, thanks I know what the check straps are and it’s not the interior light switch It’s at the top of the seal, I’ve seen a few online with a plastic plug in it not sure what for maybe to hold the seal in place ?‍♂️
Thank you appreciate it , a piccy would be great if anyone’s got one
Lee
Edited by leepol83, 03 September 2020 - 07:23 PM.
#8 mini-mad-mark
mini-mad-mark
  • 703 posts
Posted 03 September 2020 - 08:22 PM
Sorry keep forgetting by the time I get in front of the computer its dark
#9 mini-mad-mark
mini-mad-mark
  • 703 posts
Posted 03 September 2020 - 08:54 PM
Attached File  Capture.PNG   416.24K   1 downloads
Well tried to get a pic just now but the camera autofocus doesn't work in the dark so its out of focus
Also the door seal is in the way so basically a bit of a crap picture altogether  >_<
Red is the pin - its like a trim plug that you push through a flat board trim panel  -gues you're right its used to hold the seal for soem reason  - I always thought they were glued and never really paid attention to it before
Pink is the interior light switch - think I did know what that "peg" was for Tornado99....  :D
I'll try to remember to get a better pic tomorrow
#10 Pigeonto
Pigeonto
  • 967 posts
  • Local Club: ISMOC
Posted 03 September 2020 - 09:04 PM
I've recently had to attend to these following a full bare shell restoration. The original rubber seals were held in place by the plastic plug that you mention,not sure if there were 1 or 2 plugs per seal but I don't think the original type is supplied these days.
I obtained both available types but ended up using the adhesive foam type
#11 Tornado99
Tornado99
  • 750 posts
Posted 03 September 2020 - 09:17 PM
Here is what mine looks like. Was from Mini Spares and I applied it myself. Note the plastic peg lower side, which is my interior light switch.
#12 leepol83
leepol83
  • 1,744 posts
Posted 04 September 2020 - 06:09 PM
Thank you for that think I’ve got it I’ll fit them in the morning thanks again for all the help as always most appreciated thanks guys
#13 mini-mad-mark
mini-mad-mark
  • 703 posts
Posted 04 September 2020 - 08:21 PM   Best Answer
Attached File  IMG_0558.jpg   40.56K   0 downloads
