Just had the mini out the garage and I noticed a couple of drops of fluid on the floor under the drivers side radius arm. It feels greasy and smells like grease but is more like oil?
Jacked the car up and removed the wheel and noticed where the pin for the handbrake quadrant goes was wet on top of the radius arm, but also the knuckle looks like it has seen better days.
Doesn't seem to be any leaks from the brake lines. Can anyone confirm the issue? Knuckle need replacing?
