success, replaced the head gasket that seemed to have done the trick a couple of runs around the town and it it is dry finally. thanks for everyone s input..........impressed with Mini Spares shipping 4 days from UK to Canada.........its Thanksgiving here have a great Turkey
Oil Leak Backing Plate A+ Automatic
Best Answer Spider , 13 September 2020 - 05:28 AM
I'd actually be inclined to say it's coming from the head gasket. The Oil Pressure Feed to the Head is in that corner of the block. If it does leak, it tends to run down around there to the front engine plate, which can make it look like it's from the plate. There is a small part of the block above the front engine plate and below the head gasket where you should see it if it's leaking from there.
The other thing it could be from is poor machining of the block. I've had a couple of A+ blocks that have been quite poorly machined to the point where they'd leak oil, but they were both early A+ Blocks.
Go to the full post#16
Posted 11 October 2020 - 12:59 AM
