Skf Rear Wheel Bearings
Best Answer Spider , 15 September 2020 - 06:58 PM
Thanks Moke Spider, would you clean and grease in situ in the hub? If not, any idea how I remove them?
Yes, I'd just clean them in the hub, it will take a bit of doing to get all the old grease out, then you can inspect them, there's usually enough space between the cage and the races for that, then grease, fit a new seal and refit back on the car. Be sure to use a good quality grease and don't over fill it.
Posted 14 September 2020 - 08:28 PM
I’ve just come to strip the OS Rear hub and discovered that the bearings are SKF BA1B633299B Angular Contact Bearings.
Firstly, would this be normal fitment to a 1991 car?
Secondly and more importantly, how do I remove them? The inner races almost touch and I can’t see how to get behind them to drift them out!
Cheers!
Posted 14 September 2020 - 08:29 PM
Your best to use a hydraulic press on the outer races
Posted 14 September 2020 - 08:32 PM
So ball bearing not taper roller?
not original for the mini. Bu5 original for the Metro and a cheaper replacement for the Mini.
Posted 14 September 2020 - 08:52 PM
If they are OK, clean them, grease and leave them.
Posted 14 September 2020 - 08:59 PM
Posted 14 September 2020 - 10:02 PM
Yes nicklouse, Ball bearings, Angular contact.
You just need to inspect and re grease the bearing cage and roller assembly.
Posted 15 September 2020 - 06:58 PM Best Answer
Posted 17 September 2020 - 07:20 AM
Thanks Moke Spider!
I'll give that a go, I have a tub of Timken Bearing Grease, so I'll use that!
Cheers!
