Black Smoke
10 replies to this topic
#1 Jaffamini
Jaffamini
  • 49 posts
Posted 11 September 2020 - 08:14 PM
Just changed the head on my 85 mini old one cracked. Bought a second hand head that looked good, lapped in valves cleaned up and refitted. ( Was never really happy with the finish on the smaller valve seating) but fitted it. Starts and runs but puffs out black smoke when refer up and stinks of petrol.tryed adjusting carb but no difference. Compression test 3@ 113 psi 1@ 109 psi. Any ideas.
#2 sledgehammer
sledgehammer
  • 3,132 posts
Posted 12 September 2020 - 09:27 AM
check the choke mech is free to return the jet to normal running position
check needle hasn't been bent
check that the dash pot piston can move up / down freely
check dash pot damper is working & not jamming somehow
check float chamber isn't overfilling & float & valve are ok
only takes a bit of dirt under the float valve seat to let it dribble
check float vent is clear as a blockage can force fuel thru jet
best of luck
Edited by sledgehammer, 12 September 2020 - 09:30 AM.
#3 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Get the emissions set as per requirements for the year of car.
Did you change the valve stem seals?
#4 dyshipfakta
dyshipfakta
  • 1,696 posts
Posted 14 September 2020 - 09:53 AM
How long has it been layed up without being run? Not just stale juice is it. Give it a run with some fresh fuel and retorque the head and reassess would be my advice.
#5 Jaffamini
Jaffamini
  • 49 posts
Posted 15 September 2020 - 06:36 PM
Hi I have just changed my head on my 1985 998 engine,old one cracked. Runs a bit lumpy but puffs out black smoke when refer. Make no difference when adjusting fuel mixture. Plugs are black and very wet.any ideas anyone kevin
#6 robert.hedges
robert.hedges
  • 53 posts
Posted 15 September 2020 - 06:42 PM
Jaffamini I've literally just posted almost the same thing!! Lol
#7 cal844
cal844
  • 9,736 posts
  • Local Club: TFMOC
Posted 15 September 2020 - 06:46 PM
Was the old head replaced like for like?
Porting, polishing etc will make a difference
#8 sonscar
sonscar
  • 3,257 posts
Posted 16 September 2020 - 06:35 AM
Choke stuck on?float chamber flooding?Black smoke is usually too much fuel.Steve..
#9 Jaffamini
Jaffamini
  • 49 posts
Posted 16 September 2020 - 07:03 PM
Hi all. yes replaced head like for like, cleaned everything lapped in valves + new oil seals. Was not really happy with the smaller valves just could not get a shinny finish. Run fine with old head just through out loads of water out exhaust
Thanks for your replay. Kevin
#10 Jaffamini
Jaffamini
  • 49 posts
Posted 16 September 2020 - 07:19 PM
Hi thanks just got some new fuel to try,put new valve seals on. Been standing 7 years just turned over now and then. Have noticed the fuel valve at the base is a bit sticky when moving it up and down by hand.
Regards kevin.
#11 the.stroker
the.stroker
    TMF Admin
  • 4,348 posts
  • Name: Dan
Posted 16 September 2020 - 07:26 PM
Threads merged
