Why are people so scared of headliners!
Top 3 Most Fiddly Jobs On A Mini
#16
Posted 19 September 2020 - 08:02 AM
#17
Posted 19 September 2020 - 08:11 AM
I always super glue the brake/clutch master cylinder clevis pins to my finger tip to fit them, makes installation a doddle.
#18
Posted 19 September 2020 - 08:18 AM
<br />
I find upper suspension arms a pain in the arse. spinning axle and getting both nuts off. <br />
<br />
Bottom clevis on clutch arm is going to be a pain. Looks like a bolt and nut has been used. :-( <br />
<br />
</p>
Edited by no66, 19 September 2020 - 09:37 AM.
#19
Posted 19 September 2020 - 08:24 AM
Especially on a Minus where the tank barely fits in the first place.
#20
Posted 19 September 2020 - 10:33 AM
#21
Posted 19 September 2020 - 11:17 AM
cant think of anything.
just make the right tool for the job.
#22
Posted 19 September 2020 - 01:30 PM
Surely any job where you have to make a tool is on this list!
#23
Posted 19 September 2020 - 02:48 PM
I actually found the clutch pedal clevis pin a little easier than I was first expecting - I'd be tempted to add the fitment of chrome finishing trim to this list though, that required a lot of patience!
#24
Posted 19 September 2020 - 03:29 PM
Those two little bolts holding the locking plate on the top suspension arm pin
#25
Posted 19 September 2020 - 04:11 PM
Driver's side engine mounting on an automatic 998. Only managed it by aralditing nuts to the mounting.
I always worry about using R clips on the clutch and brake master cylinders because if the clevis pin turns the long end of the R clip can catch the bodywork and prevent the pedal returning fully.
Best wishes
Mike
#26
Posted 19 September 2020 - 05:30 PM
#27
Posted 19 September 2020 - 10:09 PM
Yes that task does turn the air blue and warrant at least 3 cups of tea whilst psyching yourself up for another attempt. And then when you've got them back in there's still the other side to do ....
#28
Posted 20 September 2020 - 05:15 AM
Gotta agree Nick.
The bonnet hinges aren't bad if you use three or four extensions on your ratchet.
#29
Posted 20 September 2020 - 07:57 AM
but definitely one of the most frustrating seeing how simple you’d think it would be
#30
Posted 20 September 2020 - 07:59 AM
2. Master cylinder clevis pins
3. Removing a freeflow manifold from the engine bay with a remote boxed engine without damaging paint.
