Do I need to re- torque a payen BK450 which looks to be composite?
And do 1380s have habit of going between 2 & 3 even when both surfaces are nice and true ?
( not a lot of meat there )
Thanks in advance Gray
Posted 19 September 2020 - 10:30 AM
Posted 19 September 2020 - 10:43 AM
yes.
i would say it is the most common place for them to go but not the only place,
Posted 19 September 2020 - 10:54 AM
Thanks But the reason why I ask is a mechanic told me as it was not a copper jobbie it’s not necessary?
Posted 19 September 2020 - 10:59 AM
Posted 19 September 2020 - 11:18 AM
Edited by OzOAP, 19 September 2020 - 11:18 AM.
Posted 19 September 2020 - 12:21 PM
Yes, after one or two heat cycles do a proper re-torque.
Doing each head nut in turn in the correct sequence, undo the nut half a turn then re-torque to the correct figure.
Posted 19 September 2020 - 01:09 PM
Thanks a lot . I know there’s a lot of talk about torque! There down at 42 would you consider that correct on a 1380 not that special fast road motor ?
Posted 19 September 2020 - 01:19 PM
Sorry didn’t answer your question Mechanic not a Mini specialist.
Think that’s the form on modern engines with composite head gaskets ?
