Grille Component Parts
8 replies to this topic
#1 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 21 September 2020 - 10:57 AM
Hello
Does anyone know if it's possible to buy individual slats for grilles?
I have a 93 L reg cooper SPI
I've taken the slats off to rub down, de-rust and repaint the grille frame
I'm going to pop rivet the slats back onto the frame, but 2 or 3 of the slats have some surface corrosion
A new grille is c£55
The paint and filler to carry out the corrosion repair and respray all slats would be c£35 (rattle can approach)
I'd prefer to replace only the parts I need
A completely new grille seems wasteful (but probably represents better value for money)
Thanks all
#2 Bobbins
Bobbins
  • 1,526 posts
Posted 21 September 2020 - 11:22 AM
If you have all the components it's better to refurbish them than to replace the grill, the replacement will not be the same quality, certainly my '98 has a better grill than any replacement I've come across. Try some Autosol on the lats, you might be surprised.
#3 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 21 September 2020 - 11:29 AM
That was partially what's driving my desire to keep as much of what I have
That and cost having spent a LOT on the car recently
I'm trying to avoid it becoming Trigger's Broom
I've tried autosol
Some improvement, but not really a finish I am happy with
#4 sonscar
sonscar
  • 3,251 posts
Posted 21 September 2020 - 12:47 PM
The slats are anodised,once corroded they never look the same in my experience,others may vary.Once the protective anodising as been worn through they need regularly polishing.Steve..
#5 nicklouse
  • 19,058 posts
Posted 21 September 2020 - 01:59 PM
not available singly. fix what you have or replace the whole thing.
#6 GraemeC
GraemeC
  • 7,472 posts
Posted 21 September 2020 - 02:29 PM
Or buy another one secondhand which has the slats you need in good condition, and make one out of two.
#7 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 22 September 2020 - 09:00 AM
Thanks all.
Now also pondering what to use to protect the grille from further damage from the back of the front spot lights that seem to be rubbing a little against the grille
Has anyone else had, and sorted this problem?
#8 Bobbins
Bobbins
  • 1,526 posts
Posted 22 September 2020 - 02:56 PM
My standard Rover spotlights have plenty of clearance but anywhere that I suspect might cause damage I usually add a small piece of 1mm self adhesive neoprene sheet, there's plenty available on ebay.
#9 Elwyn
Elwyn
  • Just Joined
  • 365 posts
Posted 23 September 2020 - 04:49 PM
Thanks. Mine look original, but there's some occasional, vibration driven contact. I'll head over to ebay, thanks
