@wazzah
mems-rosco,mems-scan,mems-faultcodereader,mems-logger
"only Bosch" i tread that for a fairy-tail
@andysspanners
my question was not about the lambda sensor.
Prior to a working lambda sensor the ecu has a parameter that is called lambda sensor status.This has to switch to yes, this is in most cases direcrtly after starting the engine.If lambdastatus is yes it takes some time until coolant is at 88 degrees and only then the cu shows lambda-volt swinging and closed loop.
So again :what parameters have to be fullfilled that lambda status will switch to yes or 1?
But thanks to both of you, nearly nobody answered up to now.I ask this on different forums.
