1998 Mpi Running Issues After Restoration
224 replies to this topic
#16 Quinlan minor
Quinlan minor
  • 1,382 posts
Posted 28 September 2020 - 07:04 PM
Another thing I noticed was my fuel cap hissing and a smell of fuel coming from it aswell, it’s a non vented type cap brand new ?
If it's hissing it might be a vented cap (wrongly fitted) or the seal may be faulty.
#17 leepol83
leepol83
  • 1,744 posts
Posted 28 September 2020 - 07:29 PM
It defo says non vented on it and it’s brand new, not to say it’s not faulty thow, could this cause any of my problems ?
#18 leepol83
leepol83
  • 1,744 posts
Posted 29 September 2020 - 06:24 AM
check your IACV on being stuck wide open
How do I check this ?
#19 Bruiser
Bruiser
  • 14 posts
Posted 29 September 2020 - 03:39 PM
You should be able to hear the IACV cycle when you turn the ignition on and off. Had no reference to check it, but got a 2nd hand spare. Old one silent, new one you can hear operate.
If you block the pipes of the IACV and that stops it high revving, then that kind of proves it is faulty too (even if it makes a noise) .With the pipes blocked though it won't cold idle correctly, but mine did run.
#20 leepol83
leepol83
  • 1,744 posts
Posted 29 September 2020 - 04:17 PM
Brilliant thank you for the advice, which pipes am
I blocking up ? Sorry
#21 leepol83
leepol83
  • 1,744 posts
Posted 29 September 2020 - 04:56 PM
Will this work for finding faults not cheap but maybe a good investment to have it’s as follows :-
Sykes Pickavant Acr4 Rover Mini Spi Mpi Code Reader Kit . Contains :-
1 x Acr4 handset
1 x G2 pod with Rover loaded
1 x 30211600 spi 3 pin round lead
1 x 30212400 mpi 16 pin lead
Extension cable
proper carry case
Anything else I’ll need ?
#22 leepol83
leepol83
  • 1,744 posts
Posted 30 September 2020 - 06:39 AM
Right had a play late night problem I have to date :-
Car runs and ticks over fine although abit of exhaust popping at times ?
If I cover Inlet it doesn’t stall ?
All electrics now work ?
Now I’ve been reading about the flywheel being on wrong and now panicking that’s the problem!! Surely it wouldn’t run at all if that was wrong I was mathodical in the installation marking everything it was a Borg and Beck 190mm clutch GCK100AF injection type, however I literally only replaced the friction part and not the pressure plate etc ?
Thanks and sorry I keep posting I’m just desperate to get this sorted too many sleepless nights now ?‍♂️?
Edited by leepol83, 30 September 2020 - 06:39 AM.
#23 pete l
pete l
  • 1,537 posts
Posted 30 September 2020 - 06:53 AM
get yourself one of these
https://www.aliexpre...SearchText=t300
#24 pete l
pete l
  • 1,537 posts
Posted 30 September 2020 - 06:55 AM
or one of these
https://www.aliexpre...t=delphi ds150e
#25 leepol83
leepol83
  • 1,744 posts
Posted 30 September 2020 - 10:08 AM
The t300 looks pretty good and cheap too you think this will connect ok to an mpi mini the one In the link is 2014 Newest Version:V17.8 ?
Thanks for that ??
#26 pete l
pete l
  • 1,537 posts
Posted 30 September 2020 - 01:16 PM
Mine is the v17 also and it connects to my MPI and gives all sensor readings. I compared the values to the values on my T4 (that I got later) and they are spot on.
#27 leepol83
leepol83
  • 1,744 posts
Posted 30 September 2020 - 02:51 PM
Brilliant I’ll have a look at getting one and plus it In see what it’s says
Thank you
Had a look into this and apparently I’ll need a separate lead to connect it to the car I believe it’s 5AS MEMS that’s needed For the rover mini ?
Edited by leepol83, 30 September 2020 - 03:03 PM.
#28 leepol83
leepol83
  • 1,744 posts
Posted 30 September 2020 - 03:16 PM
I now have a video of it running how can I show you guys, I have Instagram if I can put it on there ?
Thanks a lot
My Instagram name Leepol83 the video is on there if that is any good ?‍♂️
Edited by leepol83, 30 September 2020 - 03:24 PM.
#29 leepol83
leepol83
  • 1,744 posts
Posted 01 October 2020 - 07:27 AM
https://youtu.be/fncbxPJh8rs
#30 pete l
pete l
  • 1,537 posts
Posted 01 October 2020 - 08:28 AM
It comes with all the leads needed to connect to loads of different brands of cars. even the MPI
