1998 Mpi Running Issues After Restoration
224 replies to this topic
#91 Johnmar
Johnmar
  • Just Joined
  • 172 posts
Posted 03 November 2020 - 09:56 PM
T4 alternative:
http://toaf.roverki....5-00-51-already
#92 pete l
pete l
  • 1,355 posts
Posted 03 November 2020 - 10:25 PM
Toaf only connects to the Rover 75 / MG ZT
#93 Johnmar
Johnmar
  • Just Joined
  • 172 posts
Posted 04 November 2020 - 06:40 AM
I understood that the Rover 75 uses the MEMS3 but I could be wrong..
Then I read that the MEMS3 was used by MPI's.
That was interpretted as it was used by a MPI mini. But the MEMS3 is used by newer MPI cars. Their lies my mis interpretation.
Sorry.
Edited by Johnmar, 04 November 2020 - 06:46 AM.
#94 pete l
pete l
  • 1,355 posts
Posted 04 November 2020 - 07:58 AM
The Rover 75 uses a VDO SIEMENS system.
MEMS is a MOTOROLA system (if I remember correctly) !
The MPI uses the MEMS2J ECU, wich was used on the early MGFs,  I think it's MOTOROLA too !!??? not sure.
#95 FlyingScot
FlyingScot
  • 2,660 posts
Posted 04 November 2020 - 01:19 PM
Yes correct MEMS2J for MPi cars and Motorola / Rover system.
FS
#96 FlyingScot
FlyingScot
  • 2,660 posts
Posted 04 November 2020 - 01:44 PM
The Sykes Pickavant kit you bought was the right set up......
Three main reasons they don’t connect 1) user plugs the lead into the printer port on the older ACR 4 2) car ignition isn’t on 3) damage to lead or more likely wiring to the car diagnostic socket (a club member has this issue with his MPi).
On the ACR you have to use MEMS2J then 1.3 engine and do Service Reset first then do into the components to set the IACV.
The car must be at operating temperature (>88C) otherwise the software prevents auto adjustment.
You CANNOT set up the IACV without diagnostics - pumping the pedal, ignition off on etc is not doing anything that will help you, it’s simply cycling the valve (which sometimes helps where the issue is carbon build up inside).
Check for air leaks around both the inlet manifolds and the hose to the IACV (Spraying WD 40 rather than propane as suggested earlier is safer - if the revs go up you have a leak)
With the current situation it’s difficult as travel is not permitted so getting a loan of a ACR could be tricky.
FS
#97 leepol83
leepol83
  • 1,744 posts
Posted 04 November 2020 - 07:19 PM
FS
Thank you Mate for the reply, I’ve just bought a new old stock one of eBay just the body no pods or leads but it’s a start I suppose, have I done the right thing assuming as long as I get the right lead and pod this will work? I don’t need anything special to set it up ?
What is the correct pod ?
Edited by leepol83, 04 November 2020 - 07:35 PM.
#98 leepol83
leepol83
  • 1,744 posts
Posted 04 November 2020 - 08:29 PM
Will this pod work :-
Pod :-
Sykes-Pickavant ACR Rover - Mini V3 Software Pod 30350800
Harness :-
Sykes Pickavant
Advanced Code Reader ACR 2/4
Rover Specific J1962 HARNESS
Edited by leepol83, 05 November 2020 - 07:37 PM.
#99 leepol83
leepol83
  • 1,744 posts
Posted 05 November 2020 - 06:04 PM
?? polite bump on the pod
Thanks chaps
Edited by leepol83, 05 November 2020 - 07:11 PM.
#100 pete l
pete l
  • 1,355 posts
Posted 06 November 2020 - 09:00 AM
I don't know this system so can't answer sorry.
#101 pete l
pete l
  • 1,355 posts
Posted 06 November 2020 - 09:01 AM
Maybe you should start a new thread in the MPI problem forum about the Sykes-Pickavant ACR and how to use it.
#102 leepol83
leepol83
  • 1,744 posts
Posted 06 November 2020 - 04:42 PM
Thanks for the reply mate, I’ve started one ??
#103 FlyingScot
FlyingScot
  • 2,660 posts
Posted 07 November 2020 - 09:36 PM
Sorry not been on...
Yes Rover 3 pod 3050800 or later or indeed G2 or iMAP pods from Sykes Pickavant/ SP Diagnostics
V3 works in ACR2 later pods  and G2 or iMAP need ACR4 or SMART
lead needs to be 30212400 or J1962 do not use the Rover 30214000 which was designed for the MPi as it doesn’t always work.
see my post http://www.theminifo...e-reader/page-8
FS
Edited by FlyingScot, 07 November 2020 - 09:39 PM.
#104 leepol83
leepol83
  • 1,744 posts
Posted 20 November 2020 - 10:37 PM
Hi chaps finally got a machine that works ?
Here’s a few videos one with engine off and one with engine running, I’ll be honest the reading mean nothing to me whatsoever ? I’m pretty sure I need to setup the idle air control valve (stepper)
Please could someone in the know have a quick look for me would really appreciate it!!!
Thank you
https://youtu.be/g2Vf9SJ_VkY
https://youtu.be/aNtOmadsKZU
Edited by leepol83, 20 November 2020 - 10:42 PM.
#105 tmsmini
tmsmini
  • 706 posts
  • Local Club: MOASF
Posted 21 November 2020 - 04:53 PM
The readings look OK. You need to let it warm up and then see what the stepper value is. With a cool engine and 30-32 steps, the engine may be in a satisfactory range for the stepper. It looks like the lambda sensor is switching. It may take 15 minutes or more to warm up in the drive way.
