Heater Matrix Refurbishment
Posted 28 September 2020 - 06:40 PM
Does anyone have any advice on things I might miss or the process in general ?
Posted 28 September 2020 - 08:10 PM
Posted 29 September 2020 - 07:30 AM
They come apart easy enough. I cleaned mine out until it ran clear water. It wont be as efficient as a new one but so long as water can get past Im quite happy for now.
Posted 29 September 2020 - 08:20 AM
If I remember correctly there are two different length screws. Put them back in the wrong place and the flap no longer moves.
Posted 30 September 2020 - 05:38 AM
Posted 30 September 2020 - 08:14 AM
The buzzing in my heater was caused by the flap actuation mechanism on the back of the flap. It's a long time ago now, but I seem to recall that playing with this and eliminating any free play in the links stopped the noise.
Posted 30 September 2020 - 08:47 AM
If I remember rightly the flap hinges are little metal rods sitting in holes in the casings. Next time I take my heater out I've been thinking I'll use rubber grommets or nylon tophat liners to eliminate rattling here.
Posted 30 September 2020 - 09:29 AM
Posted 30 September 2020 - 10:32 AM
- You could de-scale the matrix with some citric-acid (coffee machine de-scaler).
- Ensure you replace the foam strips on the flaps (if later - i.e. post Mk2 - heaters had them I don't know).
- Lubricate the motor bearings with some sewing machine oil or similar.
