Hello all, not new to minis, but new to this forum. I hear it's the friendly place for help and advice.
Over the past months with restrictions in place i decided to overhaul the engine as the miles were building up (close to 80,000).
The block has been re-bored and new pistons fitted, crank re-ground and new shells. It's also had a new camshaft and followers and oil pump.
Head looked in good condition. I just had it skimmed to clean it up and cleaned and lapped the valves in.
Engine was put through a heat cycle ready to re-torque the head. When i shut the engine off i noticed water between the head and block.
Suspecting the head gasket i began to remove the head nuts to find they were only nipped up and not torqued down.
How i managed this error i do not know, but i called myself a few choice words for being such an idiot.
With the head off i noticed water down one of the bores, and down into the cam followers. I decided to rebuilt it, drain the oil and fit a new filter and oil to flush the system.
This time with the head torqued down i warmed it up again, then drained the oil. The head has been re-torqued
It had a new filter and oil and i've run it for the recommended 20 mins at 2,500 to bed everything in. Since then i have driven it for a couple of hundred miles
Sorry for all the rambling, but i guess my question is, should i be pulling and stripping the engine to see if i have any premature wear.
It did have the required grease on the cam lobes etc.
tia
