Story so far.
Removed entire auto power unit, replaced with 12 A+, 40 thou oversize & manual DAM 2886 rod box .
Unable to use pre engaged starter, so external solenoid and inertia starter fitted.
Brown / red trace to starter circuit which fires starter on crank. ( that works fine).
Battery + to correct terminal, with the other heavy leads from the pre engaged starter also connected.
Auto inhibitor wires connected together. Retained all spi ignition items.
Now, the hard stuff.........
Ignition on and cranking, a relay can be heard operating, stepper motor sets up, ignition light on, fuel gauge operating.
Engine cranks along nicely. Oil light goes out as pressure rises.
BUT, No fuel flow and no HT spark. Coil has 12V on both sides. No current in crank sensor circuit.
Sensor moved to front crank pulley with a trigger wheel. Extended wire lead , not crossed.
All fuses in the multi fuse box checked.
Only item changed was location of original sensor and inertia starter fitted. ( unable to locate a verto clutch and sensor ring flywheel ).SPI head retained with new temp and heat units replaced. Vacum hoses replaced.
All working without fault before power swap.
So, there it is..
What has failed?
Cheers from New Zealand.
