Auto & motor out, Replaced with Pre A+ 1275 and dam 2886 rod box.
Sensor relocated to trigger wheel on front crank pulley.
So far......
Earthed outer shield on sensor line.
Have ignition spark at 8: btdc.
fuel pump runs to prime injector body, and stops as per normal.
Engine will fire on crank, but fails to continue to run.
Injector pulse has fuel at cranking but not have fuel to run, so it appears the fuel pump is not re starting after normal shut down.
Your interest, please.
Final idea will be to return to normal distributor and an HS4, with fuel tank, etc to match...
However, as I have fuel to start, and spark, I would prefer to retain spi...
Thanks. .
(i'm in New Zealand).
