Fitting Rear Quarter Glass In Repro Panels?
10 replies to this topic
#1 bigbadad
bigbadad
  • Just Joined
  • 30 posts
Posted 19 October 2020 - 06:49 PM
Anybody done it?!
I am trying to fit original (non opening/fixed) glass in a repro panel using a repro rubber.  It seems like the glass is far too big  - I've spent four hours so far...any tips please before I buy some Lexan windows and cut them down?
#2 nicklouse
  • 17,945 posts
Posted 19 October 2020 - 07:01 PM
I recently fitted some new rubbers and found that the lexan windows I had fitted were too big. (Drivers side) needed some trimming.
#3 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,781 posts
Posted 19 October 2020 - 08:00 PM
Repo panels shouldn't cause you an issue if they are fitted correctly.
Might it be worth measuring the glass aperture on your car, post up the measurements here and then we can compare
#4 bigbadad
bigbadad
  • Just Joined
  • 30 posts
Posted 20 October 2020 - 06:58 AM
 But they fitted before with other rubbers?  So you think it's the rubbers that are my problem?
#5 bigbadad
bigbadad
  • Just Joined
  • 30 posts
Posted 20 October 2020 - 07:00 AM
Thanks Ben, you mean measure the actual hole in the panel or the size of the glass?  For the record, the glass used to fit fine before replacement quarters (and obviously new rubbers) were fitted.  Thanks
#6 sonscar
sonscar
  • 2,725 posts
Posted 20 October 2020 - 09:36 AM
I recently refitted my windows with new rubbers and it was a mission,very tight.Hold the glass in the hole and see if there is a equallish gap all round of 5mm or so.I would think it hard to fit the panels so far out without it being very obvious.Be careful.Steve..
#7 Bobbins
Bobbins
  • 1,345 posts
Posted 20 October 2020 - 09:51 AM
Is there a tool for this job?
#8 GraemeC
GraemeC
  • 7,315 posts
Posted 20 October 2020 - 10:01 AM
A tool for what job?
Measuring stuff - a tape measure or a ruler  :P
Fitting fixed quarter light glass - string/parachute cord.
Slightly aside, but interesting:
I can't remember the technical terms for the two types of seals (Googled!), but the correct way of fitting automotive glass is:
  If using the Claytonrite type seal with a locking strip you should fit the seal to the car then fit the glass by easing the rubber over the glass (no string!)
  If using the 'direct glazing' type seal which doesn't have a locking strip, you should fit the seal to the glass and then use para cord/string to fit that to the car, pulling the cord from inside the car.
Edited by GraemeC, 20 October 2020 - 10:08 AM.
#9 Ben_O
Ben_O
    Mill Road Garage
  • Paint Doctor
  • 9,781 posts
Posted 20 October 2020 - 10:10 AM
Just measure between the edges of the lips in a few places and let us know where and we can compare.
I also doubt it will be out but worth a check.
#10 Bobbins
Bobbins
  • 1,345 posts
Posted 20 October 2020 - 10:42 AM
Cheers, i knew one of those would be useful  :highfive:
#11 nicklouse
  • 17,945 posts
Posted 20 October 2020 - 11:39 AM
All that I changed were the rubbers, but the old ones were very old and were in very poor shape.
