Osf Flexi To Banjo Connection
Posted 24 October 2020 - 03:56 PM
I'm having a pretty frustrating problem trying to bleed my brakes. What should be a simple thing is proving to be a nightmare.
The front banjo to flexi connection seeped pretty badly when I went to bleed the brakes so I replaced the banjo bolt with fresh copper washers.
I went to bleed them again and still leaked badly. So I tightened it up, retried, tightened, retried etc and even at the last try it still leaked. I tried so many times that I've now ended up snapping the banjo bolt in the Flexi.
I have no idea why it keeps leaking but I'm getting rather fed up of it now.
Anything I'm missing?
Posted 24 October 2020 - 04:01 PM
Did you anneal the copper washers before you fitted them?
Posted 24 October 2020 - 04:14 PM
No as that isn't something that should have to be done with a washer from Minispares.Did you anneal the copper washers before you fitted them?
Posted 24 October 2020 - 04:37 PM
Yeah you shouldnt have to mess with the washer when they are new. My only guess would be some corrosion on one of the faces or a hair line crack in the banjo.
Posted 24 October 2020 - 05:01 PM
Sometimes what you have to do is to double up on the copper washers on the brass 2 / 3 way union.
The thread inside the flexi hose is not deep enough sometimes to take the length of the banjo bolt
Adding 2 washers below the brass union, against the hose, then 2 washers against the head of the banjo.
This should solve your problem
The copper washers needed are 233220A and 3H550 if I remember rightly. The banjo is C5192A
Edited by richmondclassicsnorthwales, 24 October 2020 - 05:09 PM.
Posted 24 October 2020 - 05:10 PM
As mentioned some flexi hoses are handed. Deep drilling for the banjo side and standard sorter drilling on the opposite side.
I would be checking the other side as well.
